jharader Posted February 22, 2008 Report Share Posted February 22, 2008 had a really bad weekend guys had it tuned and dialed in here in la ran good, once i got to glamis it ran like shit, stock carbs 300 main jet and still sounded like it was running lean asking 4 more gas, i do not want to do this but i think i might have to just purchase a 4 stroke , i am gettin tired of all the wrenching, i understand that the power does not compare, but i want to be able to ride my bike not wrench on it while out there, also could anyone recommend a good shop out here in the los angeles area for me so that they could dial the bike in for glamis conditions, thanks... Sale it! go with a 4-stroke, thats one less bike i hafta worry bout passing me... dont come back to the board wondering why your machine sounds like a whoopy cushion though Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted February 22, 2008 Report Share Posted February 22, 2008 He has NO airbox, he has K&N pods. A LOT more airflow than a box with no lid.He is lean. the differance from lid off to no air box is not going to make that big of a differance in his jetting. a 310 is right where he needs to be. at most he is one size small, but i doubt that even Quote Link to comment Share on other sites More sharing options...
lincster Posted February 22, 2008 Report Share Posted February 22, 2008 I would do a leakdown test on your bike maybe you have an air leak. Just my .02. did you just quote yourself??????? Quote Link to comment Share on other sites More sharing options...
lincster Posted February 22, 2008 Report Share Posted February 22, 2008 the differance from lid off to no air box is not going to make that big of a differance in his jetting. a 310 is right where he needs to be. at most he is one size small, but i doubt that even Lid off to no air box makes little difference???? Wow!!!!!! Never heard that before. Quote Link to comment Share on other sites More sharing options...
rubberneck Posted February 25, 2008 Report Share Posted February 25, 2008 With lid off, uni clamp on in stock box, I had 300 mains 4th notch on toomey needles with 25 pilots, air screws 1.5 turns out ran great at sea level. Went to K*N pods and had to go to 340 mains with clip on 2nd position and 25 pilots 1 turn out. Plug chop looked great bike ran great. I couldn't believe the difference the pods made on jetting. Just my experience. Quote Link to comment Share on other sites More sharing options...
1.6i Posted February 25, 2008 Report Share Posted February 25, 2008 my mods are in my sig..stock motor..its runs perfect in glamis.. Quote Link to comment Share on other sites More sharing options...
lincster Posted February 26, 2008 Report Share Posted February 26, 2008 With lid off, uni clamp on in stock box, I had 300 mains 4th notch on toomey needles with 25 pilots, air screws 1.5 turns out ran great at sea level. Went to K*N pods and had to go to 340 mains with clip on 2nd position and 25 pilots 1 turn out. Plug chop looked great bike ran great. I couldn't believe the difference the pods made on jetting. Just my experience. that is what I have been saying!!!!!!! Quote Link to comment Share on other sites More sharing options...
ohSIXshee Posted February 27, 2008 Report Share Posted February 27, 2008 i have a bone stock engine its a 06. shearer pipes and k&n pods with outerwears. 27.5 pilot 320 mains. clip is center on needle. havent ridden it yet but it started right up. my house is at sea level. should i go up to 340 main, or does that sound right? Quote Link to comment Share on other sites More sharing options...
badassbanshee479 Posted February 27, 2008 Report Share Posted February 27, 2008 do a plug chop! every motor is different and requires alittle different jetting. Quote Link to comment Share on other sites More sharing options...
lincster Posted February 27, 2008 Report Share Posted February 27, 2008 i have a bone stock engine its a 06. shearer pipes and k&n pods with outerwears. 27.5 pilot 320 mains. clip is center on needle. havent ridden it yet but it started right up. my house is at sea level. should i go up to 340 main, or does that sound right? I personally think you should go up, but I am not sure if those pipes flow like the Toomeys. But your biggest change was going to the pods. Quote Link to comment Share on other sites More sharing options...
rubberneck Posted February 28, 2008 Report Share Posted February 28, 2008 i have a bone stock engine its a 06. shearer pipes and k&n pods with outerwears. 27.5 pilot 320 mains. clip is center on needle. havent ridden it yet but it started right up. my house is at sea level. should i go up to 340 main, or does that sound right? Yep, going to need to do a plug chop to verify. When i first put the pods on I went up 2 sizes to a320 and it ran great, but the smoke ring on the plug chop was very light colored. I jumped straight to the 340s and the bike actually still ran great, but the plugs looked better, so that is where she is staying. Like i said, on my bike, the pods required 4 sizes larger over a uni clamp on in the stock box with NO lid.. If you previously had a K&N clamp on then maybe the change wouldn't be as drastic, I dont know. I have never jetted a stock bike with shearers, so I cant answer the question accurately. If it runs good and doesnt' cut out at high speed, I would leave what you have in there and do a plug chop right away. May be perfect, may be lean, may be rich. Nobody can really answer. Quote Link to comment Share on other sites More sharing options...
89bansheemx Posted February 29, 2008 Author Report Share Posted February 29, 2008 Yep, going to need to do a plug chop to verify. When i first put the pods on I went up 2 sizes to a320 and it ran great, but the smoke ring on the plug chop was very light colored. I jumped straight to the 340s and the bike actually still ran great, but the plugs looked better, so that is where she is staying. Like i said, on my bike, the pods required 4 sizes larger over a uni clamp on in the stock box with NO lid.. If you previously had a K&N clamp on then maybe the change wouldn't be as drastic, I dont know. I have never jetted a stock bike with shearers, so I cant answer the question accurately. If it runs good and doesnt' cut out at high speed, I would leave what you have in there and do a plug chop right away. May be perfect, may be lean, may be rich. Nobody can really answer. whatever to all u haters, just had a bad weekend out there, other than that have had my og shee since 89 with no problems till these last trips, as far as mods are concerned here they are k&n pods, stock carbs, t-5 s, coolhead with 20cc domes, lightened flywheel by duncan racing, boyesen reeds, TORS KIT, desert gas tanks, +2+1 armadillo arms, works a-t steelers, durablue axle, zr1 suspensions rear shock with gold valve by race tech, trail tech stock position lights that's about it... Quote Link to comment Share on other sites More sharing options...
rubberneck Posted February 29, 2008 Report Share Posted February 29, 2008 didn't know i was a hater. whatever the hell that means. you asked for help, i told you how my bike is jetted for basically the exact mods. bottom line though, nobody can tell you what jets your bike needs. we can only get you close. You have to check the plugs and evaluate how the bike is running. Next time i wont help. Quote Link to comment Share on other sites More sharing options...
lincster Posted March 3, 2008 Report Share Posted March 3, 2008 Why are we haters??? Cause we offer advice that you might not like to hear? Quote Link to comment Share on other sites More sharing options...
ohSIXshee Posted March 3, 2008 Report Share Posted March 3, 2008 Why are we haters??? Cause we offer advice that you might not like to hear? i dont mean to thread jack hahah but i had a question. it starts up fine and idles perfect when cold. when i go for a ride and its all warmed up, when i shut it off i have to give it throttle to re-start. i tried adjusting the air / fuel screws with no change 1 1/2 turns out, died if i went either way witht he screw. any sugestions. the pilot jet is 27.5. Quote Link to comment Share on other sites More sharing options...
