NEW TOP END
desert nut
I HAVE A 1996 BANSHEE NEW TOP END 65MM BORE CLEANED CARBS HAVE 300 MAIN AND 30 PILOT JET HAVE NOT COMPLETELY BROKE IN, GREAT COMPRESSION
BUT IT IS SMOKING LIKE A CRACK HOE :banghead: ON RIGHT SIDE SEEMS LIKE IT IS PASSING ALOT OF AIR ON EXHAUST ON RIGHT SIDE I NEED HELP :sick: :sick: CHECKED REED AND THEIR IS NO SPACE I AM ABOUT TO BLOW THIS UP :sick: :mad:
I'm not sure what your askin, what space are you talkin about when you checked your reeds?
JUST CHECKED TO SEE IF THEY ARE BAD PER CLYMER BUT THE WERE FINE BUT IT IS SMOKIN BAD ON RIGHT SIDE
Does the smoke look blue or white? Blue smoke is fine, ride it and it'll clear up some. White smoke would mean your burning coolant in that cylinder, if it is white check the seal of your head gasket.
first, thanks for turning caps lock off....:)
After the rebuild, did you check clearances? Did you check piston to wall? Did you check ring end gap?
What kind of oil are you using? What kind of mixture ratio?
The carbs are clean, but are they sync'd. Did you actually remove all the jets from the carbs and clean it out GOOD?
Pilot jets have very, VERY small holes. They clog easily with as little as a grain of sand or dirt...spraying some carb cleaner alone won't do it. I've taken carbs down to bare body and used carb cleaner and speaker wire/compressed air to clean 'em out.
What about compression? Did you check compression? Are you using fresh plugs? Are your carbs put back together correctly?
(Choke tube on, slides in the correct carbs, float bowls on the correct carbs?)
That ought to keep ya busy for a while....
smoking bad on right side could be crank seal sucking trans fluid, RIGHT GUYS?! i cant believe that wasnt one of the first replies! anyways, a leakdown test may be in order, and since you own a clymers manual, i reccomend reading up on that.
Nice call...absolutely right. I've only had one cup of coffee so far...LOL.
