qboronyrican Posted February 16, 2008 Report Share Posted February 16, 2008 im looking to add on my v-force reeds and 28mm carbs and was wondering if i needed or should(for performance reasons if there is any)upgrade my intake manifold and boots???? should i go with the built in crossover tube style, pro design, or vtio's or is stock just as good??? what will any of these others add if anything???? ...Also how about cascade reed stuffers, are these any good for performance????? Quote Link to comment Share on other sites More sharing options...
qboronyrican Posted February 16, 2008 Author Report Share Posted February 16, 2008 no one has any expert advice on this subject????? Quote Link to comment Share on other sites More sharing options...
Wildcardracing Posted February 16, 2008 Report Share Posted February 16, 2008 You'll be just fine running your stock intake parts with 28mm carbs. Carbs larger than 28mm will require larger intake manifolds. :thumbsup: Quote Link to comment Share on other sites More sharing options...
qboronyrican Posted February 16, 2008 Author Report Share Posted February 16, 2008 ok but what about performance wise...are the built in crossovers better and what about the reed stuffers???? Quote Link to comment Share on other sites More sharing options...
Wildcardracing Posted February 16, 2008 Report Share Posted February 16, 2008 ok but what about performance wise...are the built in crossovers better and what about the reed stuffers???? Those fancy billet intakes are just bling imo, the reed stuffers offer a gain. Quote Link to comment Share on other sites More sharing options...
qboronyrican Posted February 16, 2008 Author Report Share Posted February 16, 2008 so the stuffers and the v-forces can be used with stock manifolds and boots??? Quote Link to comment Share on other sites More sharing options...
Wildcardracing Posted February 16, 2008 Report Share Posted February 16, 2008 so the stuffers and the v-forces can be used with stock manifolds and boots??? :thumbsup: Quote Link to comment Share on other sites More sharing options...
qboronyrican Posted February 16, 2008 Author Report Share Posted February 16, 2008 any suggestions on making any modifications to the stock manifolds for the v-force's........i have heard of people doing something but not sure what and not sure if needed?????? Quote Link to comment Share on other sites More sharing options...
rubberneck Posted February 16, 2008 Report Share Posted February 16, 2008 when you use v-force with stock intakes, you have to cut part of the stock intakes off. The back side of the stock intakes protrudes in to the intake tract. You have to cut that protrusion off. Once you get it off, you will see exactly what im talking about. I used a realy sharp knife and cut it off (its rubber) worked great. I dont know if stuffers will offer a performance advantage if you stick with the stock intakes as the v-force cage matches up to the diameter of the stock intakes. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted February 16, 2008 Report Share Posted February 16, 2008 You can run 28mm carbs with stock intakes but I would just get a Boss or White Knuckle Racing intake with built in crossover tube. They are not just for looks. They move the carbs up and back so the bowl doesnt hit on the clutch arm. They also clean up the area because you dont have an external cross over tube or boost bottle. Plus if you need to replace the carb boots they are 15 bucks from Dennis Kirk. Quote Link to comment Share on other sites More sharing options...
shanYE west Posted February 16, 2008 Report Share Posted February 16, 2008 I wouldn't recommend using the cascade stuffers unless your intakes manifolds dont match the VF3 stuffer. Cascade designed the stuffers to use with there 2 into 1 set-ups. If your looking to get a new set of manifolds the BOSS and Whitekuckle are the way to go.. The built in corssover tube is nice and they make for a clean look. The whiteknuckle intakes match the VF3 stuffer so there would be no need to get the cascade stuffers. But if you get the BOSS racing intake you might have to.. Quote Link to comment Share on other sites More sharing options...
qboronyrican Posted February 16, 2008 Author Report Share Posted February 16, 2008 You can run 28mm carbs with stock intakes but I would just get a Boss or White Knuckle Racing intake with built in crossover tube. They are not just for looks. They move the carbs up and back so the bowl doesnt hit on the clutch arm. They also clean up the area because you dont have an external cross over tube or boost bottle. Plus if you need to replace the carb boots they are 15 bucks from Dennis Kirk. the 28mm carbs hit the clutch arm??? and if not then does that mean all the boss and wkr intakes do is look good and take up less space.....do they not do any thing for performance for $160????? Quote Link to comment Share on other sites More sharing options...
Hilarious Posted February 16, 2008 Report Share Posted February 16, 2008 the 28mm carbs hit the clutch arm??? and if not then does that mean all the boss and wkr intakes do is look good and take up less space.....do they not do any thing for performance for $160????? For 160$, you get a nice, shinny piece of billet and the ablilty to mount a bigger carb, than stock. IMHO. If your 28's will mount to your stockers, I'd suggest using them and cut the insides out for your vforce3's and take that 160 and put it twards a cool head or a adjustable timing plate. Quote Link to comment Share on other sites More sharing options...
qboronyrican Posted February 16, 2008 Author Report Share Posted February 16, 2008 thanks for the advice but already have the cool head and the dynatek....anything else you can think of??? Quote Link to comment Share on other sites More sharing options...
