714banshee380 Posted February 11, 2008 Report Share Posted February 11, 2008 I was in glamis this past weekend and my shee started overheating due to how hot it is... The radiator startet smoking... I have already siezed it twice so i took it easy and cruised back to camp poured water all over the raidator/motor. I was just wondering if theres anyway i can make it run cooler? I have stock radiator, bored 2 sizes over stock, ported, polished, t5's, k&n air filters, stock carbs Quote Link to comment Share on other sites More sharing options...
TexasBansheeMan Posted February 11, 2008 Report Share Posted February 11, 2008 1st. Bigger Radiator 2nd. Billet high flow water pump 3rd. Cool ice or coolant. Quote Link to comment Share on other sites More sharing options...
yamaha04 Posted February 11, 2008 Report Share Posted February 11, 2008 pro design watter impeller.and cool head. you can try running engine ice. but it will do so much. if you have overheated it before then you might want to check out your stock impeller it might be melted. Quote Link to comment Share on other sites More sharing options...
Wildcardracing Posted February 11, 2008 Report Share Posted February 11, 2008 I was in glamis this past weekend and my shee started overheating due to how hot it is... The radiator startet smoking... I have already siezed it twice so i took it easy and cruised back to camp poured water all over the raidator/motor. I was just wondering if theres anyway i can make it run cooler? I have stock radiator, bored 2 sizes over stock, ported, polished, t5's, k&n air filters, stock carbs Cool head billet ipemllor Engine Ice oversized radiator Quote Link to comment Share on other sites More sharing options...
nitroburner13 Posted February 11, 2008 Report Share Posted February 11, 2008 I was in glamis this past weekend and my shee started overheating due to how hot it is... The radiator startet smoking... I have already siezed it twice so i took it easy and cruised back to camp poured water all over the raidator/motor. I was just wondering if theres anyway i can make it run cooler? I have stock radiator, bored 2 sizes over stock, ported, polished, t5's, k&n air filters, stock carbs make sure your bike isnt too lean, that may be the reason you seized it the other two times. you could get a oversized radiator and a billet impeller and get a cool head. all of those will help a lot. Quote Link to comment Share on other sites More sharing options...
gumby6t9 Posted February 11, 2008 Report Share Posted February 11, 2008 pro design watter impeller.and cool head. you can try running engine ice. but it will do so much. if you have overheated it before then you might want to check out your stock impeller it might be melted. What yamaha04 said AND check your plastic water pump drive gear. Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted February 11, 2008 Report Share Posted February 11, 2008 Jetting is probably the cause. A properly jetted bike can run all day long in some really damn hot temps and have no problems. I have a buddy with a stock stroke cub who rides with me in temps over 100 degrees for hours on end with no issues. Easy way to solve your problem... convert to methanol. lol Check your jetting FIRST, then worry about the other parts... Quote Link to comment Share on other sites More sharing options...
714banshee380 Posted February 11, 2008 Author Report Share Posted February 11, 2008 pro design watter impeller.and cool head. you can try running engine ice. but it will do so much. if you have overheated it before then you might want to check out your stock impeller it might be melted. and what do you mea engine ice wil ldo so much? it doesnt make a difference compared to other coolants... i use coolant peak Quote Link to comment Share on other sites More sharing options...
Wildcardracing Posted February 11, 2008 Report Share Posted February 11, 2008 and what do you mea engine ice wil ldo so much? it doesnt make a difference compared to other coolants... i use coolant peak My shee was boiling over when I pushed her too hard in hot weather, switched to Engine Ice and haven't boiled it yet. Quote Link to comment Share on other sites More sharing options...
yamaha04 Posted February 11, 2008 Report Share Posted February 11, 2008 engine ice is just a different kinda of coolent. iv heard it works well and says it drops temps 10* but you cant rely on it. if you have sezied it before and keep overheadting you have a problem. tell us your jetting in your carbs and every mod you have and your elevation. and we will get it jetted for ya. also you want a pro design impeller. they have a stainless steel shaft. they are expencive but are the best. dont buy the one sthat are all buillet Quote Link to comment Share on other sites More sharing options...
bansheejoel Posted February 11, 2008 Report Share Posted February 11, 2008 id take off that radiator grill damn it doesnt even look like air can even pass through it. if it were me id get one that is more open just my .02 Quote Link to comment Share on other sites More sharing options...
yamaha04 Posted February 11, 2008 Report Share Posted February 11, 2008 good thinking yeah that does look pretty restricting. you could PM 87sheerips on here he makes some wicked grills. Quote Link to comment Share on other sites More sharing options...
wacko2000 Posted February 11, 2008 Report Share Posted February 11, 2008 Im not trying to Jack any1 thread, but I would like to change my impeller also.. Where is it located, how can I change it and is it a pain in the ass? Quote Link to comment Share on other sites More sharing options...
yamaha04 Posted February 11, 2008 Report Share Posted February 11, 2008 drain your oil and coolent take the clutch cover off. then take that plastic cover off on the front of your clutch over then take the 4 or 5 screws out that hold the little brass colored plate off. then turn your clutch over over and push the gear down and take the dowl pin out of the impeller shaft then take the gear off and pull the impeller out. . check the seal. put the new impeller back and then the plastic gear back on the shaft and re instal the dowl pin. turn the gear and make sure it drops down or is already down on the shaft and down pin. then put all the covers back on and refuil liquids. very very easy Quote Link to comment Share on other sites More sharing options...
bansheejoel Posted February 11, 2008 Report Share Posted February 11, 2008 wacko2000 here is pics of step by step how to......http://www.bluetraxx.com/tech/water_impeller.htm Quote Link to comment Share on other sites More sharing options...
