joyride Posted February 10, 2008 Report Share Posted February 10, 2008 (edited) Long story short I had my banshee for sale back in November...Before the guy came over I decided to warm it up since I hadnt ridden it since that following summer...On my way back to my house the front tie rod broke sending me over the handlebars fracturing some vertebreas in my lower back and sending the banshee end over as well...Luckily this happended to me and not the buyer...this has been my first chance to get back out and look at it and honestly I dont have the desire repair it so I have simply decided to part it out and help some fellow shee enthusiast while doing so...Everything worked fine up until that point unless other wise Noted by me...I will answer any question and do my best to describe everything as well...thanks.Shipping is not included in the prices but it will be obo and shipping will be calculated accordingly...Money order, Cashiers check or personal check will be accepted along with cash; the latter is prefered...You can also transfer money into my checking account and we can discuss fees as well...Thanks for looking... Before Wreck Engine Just had rebuilt with 4 maybe 5 tanks of gas ran through it...It has a mx port with a milled head, new wiseco pistons first time to be rebuilt, new clutch and stator along with all new gaskets...Because of the wreck it will need a new clutch cover because of a crack on the bottom left side down by the kick start and a kick start rebuild kit or a new one all together because now the old one will come off...The motor did fire right up yesterday after two kicks so a new cover and fluids and you will be good to go...this motor along with my old fmf gold series pipes pulled on t5 and t6 shees all day...I will also include a set of oem ported reed vavles and tony doukas reeds...450.xx obo Complete banshee plastics ...Race Cut plastic with front alba sticker along with alba seat cover...Rear fenders do not sag at all hardly any stressing...100.xx Old school FMF Gold series pipes and silencers...Couple of dents on each on the lower pipes along with I had to have the left one welded because of some rubbing with the frame doesnt leak or effect performance...125.xx obo Poweder coated black front bumper 35.xx obo Gas tank 10.xx Radiator 10.xx KN airfilter will fit stocks carbs with outer wear 10.xx obo Complete wiring harness with CDI ready to go 50.xx Stock carbs with TORS removed along with twist throttle 40.xx Stock coil 15.xx obo Box of bolt and nuts 20.xx Complete Banshee front brakes...bought these off of ebay awhile back...seller forget to mention the bolt that holds the hand brake to the handle bars was broken...it just needs to be drilled out 50.xx Front shocks 20.xx Powder coated black nerf bars 50.xx MSR Handle bars 10.xx Steering stem...Slightly bend does not effect performance 10.00 Rear brakes 20.00 Frame powder coated light blue with yamaha blue marble paint over the top straight...100.xx no title There will be more parts to come and if you dont see something you may want send me a pm...Since I am limeted on pictures I can post I can email anybody additional pics as well thanks Blythe Edited February 10, 2008 by joyride Quote Link to comment Share on other sites More sharing options...
blueovalboy50 Posted February 10, 2008 Report Share Posted February 10, 2008 Long story short I had my banshee for sale back in November...Before the guy came over I decided to warm it up since I hadnt ridden it since that following summer...On my way back to my house the front tie rod broke sending me over the handlebars fracturing some vertebreas in my lower back and sending the banshee end over as well...Luckily this happended to me and not the buyer...this has been my first chance to get back out and look at it and honestly I dont have the desire repair it so I have simply decided to part it out and help some fellow shee enthusiast while doing so...Everything worked fine up until that point unless other wise Noted by me...I will answer any question and do my best to describe everything as well...thanks.Shipping is not included in the prices but it will be obo and shipping will be calculated accordingly...Money order, Cashiers check or personal check will be accepted along with cash; the latter is prefered...You can also transfer money into my checking account and we can discuss fees as well...Thanks for looking... Before Wreck Engine Just had rebuilt with 4 maybe 5 tanks of gas ran through it...It has a mx port with a milled head, new wiseco pistons first time to be rebuilt, new clutch and stator along with all new gaskets...Because of the wreck it will need a new clutch cover because of a crack on the bottom left side down by the kick start and a kick start rebuild kit or a new one all together because now the old one will come off...The motor did fire right up yesterday after two kicks so a new cover and fluids and you will be good to go...this motor along with my old fmf gold series pipes pulled on t5 and t6 shees all day...I will also include a set of oem ported reed vavles and tony doukas reeds...450.xx obo Complete banshee plastics ...Race Cut plastic with front alba sticker along with alba seat cover...Rear fenders do not sag at all hardly any stressing...100.xx Old school FMF Gold series pipes and silencers...Couple of dents on each on the lower pipes along with I had to have the left one welded because of some rubbing with the frame doesnt leak or effect performance...125.xx obo Poweder coated black front bumper 35.xx obo Gas tank 10.xx Radiator 10.xx KN airfilter will fit stocks carbs with outer wear 10.xx obo Complete wiring harness with CDI ready to go 50.xx Stock carbs with TORS removed along with twist throttle 40.xx Stock coil 15.xx obo Box of bolt and nuts 20.xx Complete Banshee front brakes...bought these off of ebay awhile back...seller forget to mention the bolt that holds the hand brake to the handle bars was broken...it just needs to be drilled out 50.xx Front shocks 20.xx Powder coated black nerf bars 50.xx MSR Handle bars 10.xx Steering stem...Slightly bend does not effect performance 10.00 Rear brakes 20.00 Frame powder coated light blue with yamaha blue marble paint over the top straight...100.xx no title There will be more parts to come and if you dont see something you may want send me a pm...Since I am limeted on pictures I can post I can email anybody additional pics as well thanks Blythe I live in Odessa and would be interested in the bike as a whole. Please call me so i can talk to you about it. thanks Brian 660-441-7039 Quote Link to comment Share on other sites More sharing options...
MarineNYC Posted February 10, 2008 Report Share Posted February 10, 2008 Stator? Quote Link to comment Share on other sites More sharing options...
joyride Posted February 11, 2008 Author Report Share Posted February 11, 2008 ricky stator...only about five tanks on the set up... Quote Link to comment Share on other sites More sharing options...
smokin 2 stroke Posted February 11, 2008 Report Share Posted February 11, 2008 do u have the little clamp to bold the clutch cable o the cases Quote Link to comment Share on other sites More sharing options...
joyride Posted February 11, 2008 Author Report Share Posted February 11, 2008 ricky stator...only about five tanks on the set up... I do have the clamp but I am including it with the engine...sorry...anything else??? Quote Link to comment Share on other sites More sharing options...
lilmikey Posted February 11, 2008 Report Share Posted February 11, 2008 ricky stator...only about five tanks on the set up... Pm sent, dibs on complete motor Quote Link to comment Share on other sites More sharing options...
lilmikey Posted February 11, 2008 Report Share Posted February 11, 2008 Pm sent, dibs on complete motor did you get my pm? I am interested in complete motor, lets deal. have cash and Paypal Quote Link to comment Share on other sites More sharing options...
MikeZilla Posted February 11, 2008 Report Share Posted February 11, 2008 $525 for the motor.............plus shipping Quote Link to comment Share on other sites More sharing options...
joyride Posted February 12, 2008 Author Report Share Posted February 12, 2008 $525 for the motor.............plus shipping Sorry to just get back to everyone I had a local guy that was interested in the whole shee and decided tonight not to get it....I do have a local sale pending tomorrow on the engine right after that guy came by yesterday...If it fall through I will get back with everybody...all pms are replied to...thanks Blythe Quote Link to comment Share on other sites More sharing options...
GLAMIS111 Posted February 12, 2008 Report Share Posted February 12, 2008 Is the Ricky stator a 200 watt if so how much? Quote Link to comment Share on other sites More sharing options...
joyride Posted February 12, 2008 Author Report Share Posted February 12, 2008 Is the Ricky stator a 200 watt if so how much? Yes it is but its going with the engine...thanks... Quote Link to comment Share on other sites More sharing options...
cato Posted February 12, 2008 Report Share Posted February 12, 2008 PM sent Thanks Yes it is but its going with the engine...thanks... Quote Link to comment Share on other sites More sharing options...
joyride Posted February 13, 2008 Author Report Share Posted February 13, 2008 PM sentThanks Rear brakes, bolts, reeds and reed cage are sold...Motor is pending sale waiting on payment...All pms are replied to...thanks...Blythe Quote Link to comment Share on other sites More sharing options...
scjandllj Posted February 13, 2008 Report Share Posted February 13, 2008 (edited) i'll take dibs on the carbs please. email is scjandllj@yahoo.com phone # is 717 762 7568 SeAn Edited February 13, 2008 by scjandllj Quote Link to comment Share on other sites More sharing options...
