YO1234 Posted February 7, 2008 Report Share Posted February 7, 2008 I have a 2000 banshee and i was wondering if there are any aftermarket bulbs that fit into the stock lights but are brighter or if there are any aftermarket lights that are about the same size as stock but are brighter if you guys knew anything that would be good Quote Link to comment Share on other sites More sharing options...
streetshee Posted February 7, 2008 Report Share Posted February 7, 2008 you can take the original lens out of the headlight and replace it with a "bates" style lens,but you have to improvise how to fix it into the shees unit,i used a 2pk high strength glue,araldite will work. :biggrin: Quote Link to comment Share on other sites More sharing options...
Wildcardracing Posted February 8, 2008 Report Share Posted February 8, 2008 I have a 2000 banshee and i was wondering if there are any aftermarket bulbs that fit into the stock lights but are brighter or if there are any aftermarket lights that are about the same size as stock but are brighter if you guys knew anything that would be good I saw an article where a guy added a voltage regulator/rectifier to his lighting circuit and installed a battery so he was able to run DC Headlights (much brighter and less affected by rpm changes) Quote Link to comment Share on other sites More sharing options...
crazybanshee Posted February 8, 2008 Report Share Posted February 8, 2008 Ricky Stator has aftermarket bulbs that are bright white instead of the stock yellowish tint. They work great on a stock stator. Quote Link to comment Share on other sites More sharing options...
YO1234 Posted February 8, 2008 Author Report Share Posted February 8, 2008 alright thanks u guys Quote Link to comment Share on other sites More sharing options...
shee rips Posted February 9, 2008 Report Share Posted February 9, 2008 (edited) Ricky Stator has aftermarket bulbs that are bright white instead of the stock yellowish tint. They work great on a stock stator. which ones would fit in the stock lights? the sweet blue ones hopefully? bottom left pic click here Edited February 9, 2008 by shee rips Quote Link to comment Share on other sites More sharing options...
crazybanshee Posted February 10, 2008 Report Share Posted February 10, 2008 I think those were the ones. If you call they can tell you. I know they are nice and bright. Quote Link to comment Share on other sites More sharing options...
bansheeman1988 Posted February 10, 2008 Report Share Posted February 10, 2008 which ones would fit in the stock lights?the sweet blue ones hopefully? bottom left pic click here Yup go with those for a good cheap upgrade. Got them on my 03 Big Bear and are a perfect white color. If you really want some light output, look into HID's, the manmade sun! :biggrin: Quote Link to comment Share on other sites More sharing options...
shee rips Posted February 10, 2008 Report Share Posted February 10, 2008 HIDs would be sweet, but i dont feel like doing a dc conversion. some fresh white looking lights would be sweet though, and if they are a bit brighter then bonus. that blue tint would probably be like the "asshole lights" that people put in their cars :cool: Quote Link to comment Share on other sites More sharing options...
jayzx10r Posted February 12, 2008 Report Share Posted February 12, 2008 I have a 2000 banshee and i was wondering if there are any aftermarket bulbs that fit into the stock lights but are brighter or if there are any aftermarket lights that are about the same size as stock but are brighter if you guys knew anything that would be good Check out a set of PIAA bulbs. Awesome!! You need the H6M bulbs. Night and day difference. Quote Link to comment Share on other sites More sharing options...
blowit Posted February 12, 2008 Report Share Posted February 12, 2008 (edited) I saw an article where a guy added a voltage regulator/rectifier to his lighting circuit and installed a battery so he was able to run DC Headlights (much brighter and less affected by rpm changes) Resistive loads (aka-light bulbs) do not care if power is AC or DC. DC will not make a bulb brighter but a decrease in resistance will. The battery will help sustain power at lower rpms and act as a DC capacitor to smooth ripple voltage that you would see as pulsing at idle. The biggest changes in over all light output will be increased wattage of the bulb or increase size and reflective properties of the housing. Bigger is better. Brandon Edited February 12, 2008 by blowit Quote Link to comment Share on other sites More sharing options...
