Noss Head install question
F.BEJARANO
Just got it in and am fixing to begin install. Just wondering if the small o rings that slide over the studs go in between the head and top porion or cover piece or after the top portion under the nuts?
Those orings go over the stud between the two main head pieces. You can see the recesses in the base plate where the orings fit. Call if you have any questions during the installation.
-David
