Eric6272 Posted February 11, 2008 Report Share Posted February 11, 2008 I tried using a C clamp and channel locks and still no dice. I cant get the piston in far enough to even get the pads to fit on. Its pissin me off! I have never had this many problems with just a simple pad slap. The piston is still sticking out about 1/4" I took the cap off the res. and the bleeder valve and still nothing. Im about to start looking for a new caliper..... Quote Link to comment Share on other sites More sharing options...
inthemail Posted February 11, 2008 Report Share Posted February 11, 2008 thats a bitch... wd40 it mabye? i had quite a problem once but after some forcing i DID get it to go back in..... good luck Quote Link to comment Share on other sites More sharing options...
FireHead Posted February 11, 2008 Report Share Posted February 11, 2008 I tried using a C clamp and channel locks and still no dice. I cant get the piston in far enough to even get the pads to fit on. Its pissin me off! I have never had this many problems with just a simple pad slap. The piston is still sticking out about 1/4" I took the cap off the res. and the bleeder valve and still nothing. Im about to start looking for a new caliper..... Maybe you need to try pulling the piston out of th caliper and sseing if there is a bur or something (you could have alot of rust in there also) in the bore that is preventing the piston from fully returning. Quote Link to comment Share on other sites More sharing options...
Eric6272 Posted February 11, 2008 Report Share Posted February 11, 2008 Maybe you need to try pulling the piston out of th caliper and sseing if there is a bur or something (you could have alot of rust in there also) in the bore that is preventing the piston from fully returning. Yeah thats a really good possibility. I have the Clymer manual and i was just reading over the disassembly of the caliper. So i might just go ahead and do that. Quote Link to comment Share on other sites More sharing options...
DjLeOo Posted February 11, 2008 Author Report Share Posted February 11, 2008 Yeah thats a really good possibility. I have the Clymer manual and i was just reading over the disassembly of the caliper. So i might just go ahead and do that. Yeah take the res apart it might be the o ring and rust !!! Guys my rear brake is alive !!!! a friend brought over this suction gun he attached to the rear brake .. which sucks everything out of the lines !!!!! a 2 minute fix !! and i was breaking my head !!! drained it and its working perfect !! Quote Link to comment Share on other sites More sharing options...
DjLeOo Posted February 11, 2008 Author Report Share Posted February 11, 2008 ............do you mean my Swedish Penis Englarger pump? :ninja: Thats exactly what we used !! lol Quote Link to comment Share on other sites More sharing options...
