hi all,
i was wondering, does anyone have any knowledge on gasket kits. i noticed that there are a lot of different manufacturers for these. how about tusk, rockymountains house brand? or should i get some made by cometic? any help would be great, i really need to get this thing built and broken in by presidents day weekend, thanks.
hi all,
dont get cometic, I would trust tusk over cometic, but your best bet may be OEM.
I've had good luck with Tusk, Athena, & Weisco. I've also used K&K but Thought the craftmanship could be better. I never had bad luck with any including Comtec, Just make shure you Surfaces are free of any old Gaskett Remnants and that you use a Torque Wrench ( Good&Tight ) Dosen't cut it. Also Run the Shee for about 5-10 Min then Retorque. This Method has never done me wrong.
I have not had any because I refuse to run them. Heard some bad stuff is all.
This is the first time I have heard bad about Cometic.
Anything in particular you would like to share?
I just buy a couple Base gaskets, and reed gaskets from a guy on ebay. He cuts his own. Those are the only two gaskets you really need if you do a top end, unless you need a head gasket. I run a cool head.
The head gaskets are flat and don't seal up as nice as others that have the OEM raised portion. Gaskets are kinda cheap so I'd rather get something decent. Nothign like spending $300 to drive to the dunes and having a head gasket leak...
Of the different gaskets I've used (OEM, Tusk, Vito's) the Athena's were the only ones that I'd NEVER use again----------> poor quality and they leaked (junk).
Edited by bansh03
And just think they make pistons too :down:
