Kolt45 Posted January 21, 2008 Report Share Posted January 21, 2008 Hopefully someone out there will know the answer to this. I have Toomey T-3 (uncut) pipes and just upgraded to PJ 34mm carbs with a modquad intake. The problem i have is the T-3's seem to ride low on the frame so there is no room for the carbs to sit and the air filters are touching the pipes. Was this a T-3 problem and if so is there a way around it? I have seen alot of banshee's listing this setup, but damn if i can get it to fit. The Modquad intake moved the carbs back about an inch, but there is room if the pipes would ride up higher. Thanks in advance for any ideas. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted January 22, 2008 Report Share Posted January 22, 2008 When I was running T5's with PWK 33's Boss racing intake, I had to have the LH carb top tilted in a little to clear the pipe. I also had to use a cascade heat wrap on the LH singer tube so I wouldnt melt my outer wear. I now have cpi's and they go out a round the carb a little. I still run the heat wrap on the LH stinger tube so I dont melt an outerwear. Those heat wraps insulate good enough that my air filter lays against it. Are your POD filters straight or angled flange. I have 10 deg angle flanges on mine as well. Here are some pics. Quote Link to comment Share on other sites More sharing options...
Kolt45 Posted January 25, 2008 Author Report Share Posted January 25, 2008 Thanks for the reply, the pictures really helped. There is no way to fit T-3 pipes, 34mm carbs and a modquad intake into that space! T-5's on the way! Thanks, Kolt Quote Link to comment Share on other sites More sharing options...
