jbooker82 Posted January 24, 2008 Report Share Posted January 24, 2008 That is kind of wierd. 1.5 probably means 1.5mm over stock wich would be 65.50mm. Are they forged? Any brad on the box. When I did my 4 mill on my raptor 660R it came with a CP piston. CP is a very good brand. I think the box was black with CP in blue. josh Quote Link to comment Share on other sites More sharing options...
jayzx10r Posted January 24, 2008 Report Share Posted January 24, 2008 i guess i will just get the jugs ported then. can i still use my stock carbs and reeds? i want to buy some new air filters, what do you think about the single stage foam filters made by UNI? they go for about 14 bucks each at rockymountainatv.com. i pretty much ride at glamis, and glamis only. for me it is sand or nothing, thanks in advance. After some discussion on this site, the overwhelming majority favored running 2 K&N gauze type oiled filters with an Outerwears sock over them for sand use. Read up!! http://www.bansheehq.com/forums/index.php?showtopic=84005 Quote Link to comment Share on other sites More sharing options...
bunboy1 Posted January 25, 2008 Author Report Share Posted January 25, 2008 That is kind of wierd. 1.5 probably means 1.5mm over stock wich would be 65.50mm. Are they forged? Any brad on the box. When I did my 4 mill on my raptor 660R it came with a CP piston. CP is a very good brand. I think the box was black with CP in blue. josh yeah they are 65.5mm and the brand on the box says hotrods stroker pistion. i got them from motorsportsoutlet.com for 80 bucks a piece. i don t suggest any one buy anything from them, because they kind of suck. for now on i am going to stay with rockymountain. thanks. Quote Link to comment Share on other sites More sharing options...
bunboy1 Posted January 25, 2008 Author Report Share Posted January 25, 2008 After some discussion on this site, the overwhelming majority favored running 2 K&N gauze type oiled filters with an Outerwears sock over them for sand use. Read up!! http://www.bansheehq.com/forums/index.php?showtopic=84005 hi there, i already have k&n pods for the stock carbs and i had a bad problem with them falling off? i was thinking the foam filters would be lighter and stay on better. if you know any tricks on keeping them on, please let me know, thanks. Quote Link to comment Share on other sites More sharing options...
Cory9584 Posted January 25, 2008 Report Share Posted January 25, 2008 mine like to fall off also, i think the problem is that they make them to fit different size carbs so the fit isnt going to be that great unless your using the biggest carb the filter will accept. Btw you will be really happy with your engine, it sounds like the same one i got and im really impressed with mine Quote Link to comment Share on other sites More sharing options...
2strokespirit Posted January 25, 2008 Report Share Posted January 25, 2008 I know that just running a spacer plate is NOT the way to go with a 4mm, you do not gain allot of HP, but you would be surprise how much torque you gain.... If I had to do it again, I would go for the 795s with the cut domes and porting... Quote Link to comment Share on other sites More sharing options...
