t.o.r.s question
bansheejoel
hmm it seems to idle pretty good....this box directly above the left pipe is the right box isnt it? just want to make sure its not like the cdi box....thanks
Check your wiring harness. I dicked around with my shee having a problem with anything above idle and it turned out I had a short in my harness. If your parking brake switch is malfunctioning it will do the same thing. Idle but when you try to rev, it bogs and misses. If thats the case, disconnect the wire that comes off the clutch lever and see if it works. Thanks to all the guys on BansheeHQ for that little tidbit of info!!!
