dj_diablo54 Posted January 18, 2008 Report Share Posted January 18, 2008 Going to put on the cool head tonight when I get off of work. Does anyone have any sugestions or is it pretty simple to install? Quote Link to comment Share on other sites More sharing options...
dajogejr Posted January 18, 2008 Report Share Posted January 18, 2008 Use a thin layer of grease on the orings so they stick and don't fall out/kink when installing it. Take your time....save your stock head for the torque tightening pattern, reference that. I go 10 Ft. lbs all the way around, then 15, 20...then 22. Nice even torque. Quote Link to comment Share on other sites More sharing options...
dj_diablo54 Posted January 21, 2008 Author Report Share Posted January 21, 2008 Use a thin layer of grease on the orings so they stick and don't fall out/kink when installing it.Take your time....save your stock head for the torque tightening pattern, reference that. I go 10 Ft. lbs all the way around, then 15, 20...then 22. Nice even torque. Ok I am finished with putting everything on. So is there anything else I have to do before I try and start it up Quote Link to comment Share on other sites More sharing options...
bink98xcab Posted January 21, 2008 Report Share Posted January 21, 2008 well i just put my noss head on wednesday and just double check evrything and check for leaks after you start it, and retorque the nuts after you ran it for a short period Quote Link to comment Share on other sites More sharing options...
dj_diablo54 Posted January 21, 2008 Author Report Share Posted January 21, 2008 well i just put my noss head on wednesday and just double check evrything and check for leaks after you start it, and retorque the nuts after you ran it for a short period Well tried for ten mins to start and it did not start. I was pissed so I will try again tomorrow morn and re check everything then if that does not work look to you guys for some help Quote Link to comment Share on other sites More sharing options...
lincster Posted January 21, 2008 Report Share Posted January 21, 2008 Did you put spark plugs back in it? Did you hook the plug wires up right? Did you switch the plug wires and try it? Quote Link to comment Share on other sites More sharing options...
dj_diablo54 Posted January 21, 2008 Author Report Share Posted January 21, 2008 Did you put spark plugs back in it?Did you hook the plug wires up right? Did you switch the plug wires and try it? Check Check and I will try that now Quote Link to comment Share on other sites More sharing options...
csrmel Posted January 21, 2008 Report Share Posted January 21, 2008 you can use grease or antiseize. i like the antiseize because it seems to stay there longer. but grease works too. either way when you eventually need to disassemble the cool head to work on the motor having grease or antiseize keeps the parts from sticking together so they come apart easy. dont forget to grease or antiseize the sparkplug threads too. Quote Link to comment Share on other sites More sharing options...
dj_diablo54 Posted January 22, 2008 Author Report Share Posted January 22, 2008 (edited) you can use grease or antiseize. i like the antiseize because it seems to stay there longer. but grease works too. either way when you eventually need to disassemble the cool head to work on the motor having grease or antiseize keeps the parts from sticking together so they come apart easy. dont forget to grease or antiseize the sparkplug threads too. Thanks I got it started but the thing revs up like it is going full throttel. How do i calm it down. Sorry if the question is dumb but this is my first time doing everything myself Edited January 22, 2008 by dj_diablo54 Quote Link to comment Share on other sites More sharing options...
fox_forma Posted January 22, 2008 Report Share Posted January 22, 2008 sounds like you have an air leak somewhere. Did it run fine before the cool head install? Quote Link to comment Share on other sites More sharing options...
dlnoss Posted January 22, 2008 Report Share Posted January 22, 2008 Check if the throttle cables are in a bind from working around them. Quote Link to comment Share on other sites More sharing options...
dj_diablo54 Posted January 22, 2008 Author Report Share Posted January 22, 2008 sounds like you have an air leak somewhere. Did it run fine before the cool head install? Yea it ran fine before i put the cool head on, I also got the cylinders worked on Quote Link to comment Share on other sites More sharing options...
dj_diablo54 Posted January 22, 2008 Author Report Share Posted January 22, 2008 Check if the throttle cables are in a bind from working around them. You know now that I think about it did feel a bit different with the throttle cable did feel a bit harder, I will take the gas take off and check it out thanks for the heads up Quote Link to comment Share on other sites More sharing options...
dj_diablo54 Posted January 27, 2008 Author Report Share Posted January 27, 2008 Ok guys I need some help it starts fine and Idles fine but when I push the gas nothing happens for a bit then it revs up really high throttle response is not good and it just revs high. I need some help does anyone one know what I need to do????? Quote Link to comment Share on other sites More sharing options...
dj_diablo54 Posted January 28, 2008 Author Report Share Posted January 28, 2008 Ok guys I need some help it starts fine and Idles fine but when I push the gas nothing happens for a bit then it revs up really high throttle response is not good and it just revs high. I need some help does anyone one know what I need to do????? I know some people say air leak but from where, Any help would be awsome, I want to get this bike running so I can see what all my money has gotten me. Quote Link to comment Share on other sites More sharing options...
