Transmission
im spliting the cases and going to run them threw a diesel bath i was just woundering ... can i just pull the transmission gears out and averything else...clean it up and put it all back in or is there a certain order to it all?
ohh and does anyone have jeff from FAST racing screen name i goto checkout an order i place.
You can pull the transmission gears out and everything else clean em up and put it all back in,but their is a certain order. Once you have them split
1)remove the 2 dowel pins
2)remove the counter shaft
3)remove the main shaft
4)remove the 2 countershaft bearing clips from the lower crank case
I recomend you get a book Clymer is the bomb.If you want a better idea of what it will take,do a search Big Red started a post a while back with pics of him splitting the cases.
