LSR ball joints ream
Troubledsol
Okay I searched though 30+ pages and didnt find a good answer so here we go I recently purchased a set of LSR +2 +1 arms and the joints and alright but I need to ream the spindles what is the correct size taper reamer I will need to use
What are these ball joints I have read I can use 1 ton chevy tie rod ends or 79 Ford Contour something is there any truth to this if so that awesome to go get them easily if they go bad
Last thing can I run YFZ spindles I read that it will make me a bit wider and I want them for the better brakes but isnt the angle for the ball joints different
Thanks
You can purchase aftermarket ball joints for about $25 each that will fit you a-arms and not require you to ruin a good set of spindles. I think Lonestar sells them, checkout their website and call them to make sure. They were not always available. YFZ spindles are different they may work but probably not right.
