Cable Luber
shee4speed
I have the Cable Life kit. Comes with a can of lube, and the luber. You still have to take 1 end loose up by the handle bar. You put the luber on and put the straw from the can in the hole and it forces lube down in to the cable. I still seem to get oil all over my hands though. The cable life luber has 3 different places for 3 different thickness of cables, and it has 2 screws to really sinch it down.
The only cable I worry about is the clutch cable...
They're nice to have, but not a big deal if you don't.
I've taken the end of the straw on a can of liquid wrench or WD40, flattened it a little, and tried to stick in inbetween the cable and the sheath...
Tiny spray....move the cable in and out to work it's way down.
You'll be amazed how nice your clutch pull is with a little lube and cleaned up perch!!!
