o-rings on hot-rods crank
sinisterboo
well i went ahead and split my cases to make sure there wasnt anything else to sneak up and bite me in the ass before i "cub" it, and i noticed the orings on the crank bearings were all tore up. what is the purpose of these? btw, its a hot-rods crank, and the bearings still feel great.
How do you replace the center o rings. Going to try to streatch them over the crank and hope hey srink back down?
theres o ring kits from grainger. you can cut the size you need and use a dab of krazy glue to make the ring without stretching the shit out of it. i have done it on coolheads.
i would think that if the oring was too thick, the cases would still seal up, the oring would just mash flat.. not sure though. what if you said the hell with it and left the orings off?
In the past I have used some locktite or bearing locking compound on ONE casing, otherwise it is hell to split the casings, never had a problem. Just 2 - 3 drops..
