350BANSHEE350 Posted January 15, 2008 Report Share Posted January 15, 2008 4000 feet and 106 psi sounds right on dot for a stock bore motor right just pipes and filter so how much can i shave off the head to still run pump91? Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted January 15, 2008 Report Share Posted January 15, 2008 4000 feet and 106 psi sounds right on dot for a stock bore motor right just pipes and filterso how much can i shave off the head to still run pump91? I would shave 30 off of it and reinstall the head. Check squish, and do a compression check. You can always take more off later but it is kinof hard to put it back on. I think around 40 tho you have to have the chamber reshaped. Quote Link to comment Share on other sites More sharing options...
350BANSHEE350 Posted January 15, 2008 Author Report Share Posted January 15, 2008 is it .30 or .030? thanks Quote Link to comment Share on other sites More sharing options...
350BANSHEE350 Posted January 15, 2008 Author Report Share Posted January 15, 2008 oh and what the hell is squish clearance and how do i measure it? Quote Link to comment Share on other sites More sharing options...
gemini Posted January 15, 2008 Report Share Posted January 15, 2008 is it .30 or .030?thanks its .030" Quote Link to comment Share on other sites More sharing options...
