fastrthnu Posted January 13, 2008 Report Share Posted January 13, 2008 This has been happening for some time now, and its starting to piss me off. On a full tank everything is fine, but once it gets down lower than a half, gas just will not stop comming up out of the vent tube. I have an extra long peice of it cut and looped and tied off, and gas will come out like it just out of the petcock damn near. I have to loosen the cap for it to stop and if I tighten it again, itll start again. If I dont tie it off its the same,. no matter what variable. Bad cap? Quote Link to comment Share on other sites More sharing options...
Hilarious Posted January 13, 2008 Report Share Posted January 13, 2008 That is very strange. Have you got a stock gas cap? When you loosen the cap can you hear a rush of air escaping the gas tank? The check valve in the cap may be bad. :shrug: Quote Link to comment Share on other sites More sharing options...
fastrthnu Posted January 13, 2008 Author Report Share Posted January 13, 2008 That is very strange. Have you got a stock gas cap?When you loosen the cap can you hear a rush of air escaping the gas tank? The check valve in the cap may be bad. :shrug: Yea, I can hear the preasure escape when I loosen the cap. Guess thats an excuse to buy a fancy new cap. Quote Link to comment Share on other sites More sharing options...
350BANSHEE350 Posted January 13, 2008 Report Share Posted January 13, 2008 what cap you got? i have the tusk one and the vent tube works good but gas does leak take the tube of and suck it or blow it not sure which i think you need to suck it yeah suck it. if it works good then stuff a spare main jet in the tube and that will stop the gas from coming out but not air flow .. as long as you have some Quote Link to comment Share on other sites More sharing options...
fastrthnu Posted January 13, 2008 Author Report Share Posted January 13, 2008 what cap you got? i have the tusk one and the vent tube works good but gas does leaktake the tube of and suck it or blow it not sure which i think you need to suck it yeah suck it. if it works good then stuff a spare main jet in the tube and that will stop the gas from coming out but not air flow .. as long as you have some Its a stock one. I tried taking the smaller check ball out, and that seemed to help some. But some still came out when Id rattled it good. Quote Link to comment Share on other sites More sharing options...
350BANSHEE350 Posted January 13, 2008 Report Share Posted January 13, 2008 just spend 30 bucks and get a tusk one from rmatv its only money mine works good, i have my 07 stock cap lying around somewhere kinda orgot about it lol Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted January 14, 2008 Report Share Posted January 14, 2008 I have a long vent tube that goes down to the bottom frame tube by the lower a arm. I have an aftermarket cap that doesnt have a check valve. So it seeps a little fuel out. That way the fuel doesnt spill on the plastic or other parts. If it was just gas I wouldnt worry but after a while the oil build really atracts dirt. So i just vent my fuel tank clear down. Quote Link to comment Share on other sites More sharing options...
peak-j Posted January 14, 2008 Report Share Posted January 14, 2008 Buy a tusk, mine did that so I bought a new one. Works fine. Quote Link to comment Share on other sites More sharing options...
CombatTalon2 Posted January 14, 2008 Report Share Posted January 14, 2008 I had this exact problem the other day. I opend up the cap and removed the piece of cloth that is just a filter i assume, after i removed it and put the check balls back in place i have NO Leak at all. I run an inline fuel filter, so if the vent tube sucks some dust im not too worried about it. Quote Link to comment Share on other sites More sharing options...
