530grafix Posted January 13, 2008 Report Share Posted January 13, 2008 finish putting the intakes and carbs,pump and fuel lines on, problem is this. when i Kick it over it revs real high. slides are bottomed out. idel screws are all the way out and adjusters on top of carbs are all the way down. leak down test was good. WTF!!! any ideas? thanks Quote Link to comment Share on other sites More sharing options...
alcoholbanshee Posted January 13, 2008 Report Share Posted January 13, 2008 finish putting the intakes and carbs,pump and fuel lines on, problem is this. when i Kick it over it revs real high. slides are bottomed out. idel screws are all the way out and adjusters on top of carbs are all the way down. leak down test was good. WTF!!! any ideas? thanks You are very lean.....Tell us a bit about your setup.....what carbs... what jets......etc etc etc!!! Quote Link to comment Share on other sites More sharing options...
530grafix Posted January 13, 2008 Author Report Share Posted January 13, 2008 You are very lean.....Tell us a bit about your setup.....what carbs... what jets......etc etc etc!!! 55 piot, .120 main dump .120 38 mm airstrykers and the rest is in my sig. Quote Link to comment Share on other sites More sharing options...
00tbanshee Posted January 13, 2008 Report Share Posted January 13, 2008 55 piot, .120 main dump .120 38 mm airstrykers and the rest is in my sig. what are the needles? Quote Link to comment Share on other sites More sharing options...
530grafix Posted January 13, 2008 Author Report Share Posted January 13, 2008 what are the needles? EGN middle clip Quote Link to comment Share on other sites More sharing options...
