LiftdT4R Posted January 11, 2008 Report Share Posted January 11, 2008 Hey, what's up? Bought a set of Nology wires, and a Nology coil, I was wondering how you guys are munting the coil to the bike. It looks like the 2 bolt holes on the Nology coil are way closer together then the stock coil holes. Thanks, :beer: Quote Link to comment Share on other sites More sharing options...
BaNsHeeJuNkEy Posted January 11, 2008 Report Share Posted January 11, 2008 bolt one to one hole and take a peace of metel with two holes the distance you need them. and bolt the metel to one hole and nut and bolt to the coil. did it to myfriends and doesn't go anywere. Quote Link to comment Share on other sites More sharing options...
LiftdT4R Posted January 11, 2008 Author Report Share Posted January 11, 2008 bolt one to one hole and take a peace of metel with two holes the distance you need them. and bolt the metel to one hole and nut and bolt to the coil. did it to myfriends and doesn't go anywere. That's what I was thinking, guess I gotta get off my ass and try to find something. I thought maybe I was missing a bracket, or there was a clever way to do it without fabricating anything. Quote Link to comment Share on other sites More sharing options...
BaNsHeeJuNkEy Posted January 11, 2008 Report Share Posted January 11, 2008 na not that i know of. his didn't come with one either but only took me 2 mins to make one. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted January 11, 2008 Report Share Posted January 11, 2008 I used a pice of angle aluminum. Bolt the coil to one side and the other side bolts to the frame. That way the coil hangs like the stock one. Quote Link to comment Share on other sites More sharing options...
BaNsHeeJuNkEy Posted January 11, 2008 Report Share Posted January 11, 2008 I used a pice of angle aluminum. Bolt the coil to one side and the other side bolts to the frame. That way the coil hangs like the stock one. i like that idea maybe a little stronger too. and look a little better maybe. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted January 11, 2008 Report Share Posted January 11, 2008 I trimmed the excess off the nology coil side so it looks like a bracket instead of a pice of anlge aluminum. Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted January 13, 2008 Report Share Posted January 13, 2008 I built one for Bansh-eman and sent it to him. steel sheet metal. Put it in the sheet metal brake bender and drilled 4 holes in it. Then I rounded off the corners and it was all good. Quote Link to comment Share on other sites More sharing options...
FireHead Posted January 13, 2008 Report Share Posted January 13, 2008 I have a cuple different things I have done, but for an OEM frame, bending a piece of stainless steel sheet is the way to go. :geek: Quote Link to comment Share on other sites More sharing options...
