530grafix Posted January 7, 2008 Author Report Share Posted January 7, 2008 That is all I was saying. If he is going to go the reed spacer route put it inbtween the cylinder and reed because it would have a bigger pressure pulse. Dirlling the cylinder would be the best way to go though. You could always put a threaded pluge in it if you decided you didnt want to run alky any more. Okay, I think Ill just drill the Cylinder i can go in the top right. my in frames are kinda in the way to bring a line around.. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted January 7, 2008 Report Share Posted January 7, 2008 Wherever you see fit. I have a friend that drilled the bottoms and used a 90 degree fitting for a very, very clean look. Granted most of us run out of frames, but I understand!! Quote Link to comment Share on other sites More sharing options...
