juicedaracer Posted January 31, 2008 Report Share Posted January 31, 2008 that's rude of them! can they do that? I can pick between lamda or afr.... I use actual afr meaning.....12:1... blah blah. My whole table is mostly in the boost area. I only use 36boxes for under 100kpa. the rest of the 144 box table are from 100kpa to 260kpa which is the max of my MAP sensor (for now) around 22psi. under boost I have mostly around 11.5-13.0. Obviously the higher the boost the lower the AFR target. It works well. RIGHT!!!! :biggrin: :thumbsup: :wink: don't worry... streetshee is reading up on some things. turbo shee thats easy just go to www.trickracing1.com they got everything you need for a turbo setup :biggrin: Quote Link to comment Share on other sites More sharing options...
TurboBanshee420 Posted January 31, 2008 Report Share Posted January 31, 2008 They do have a turbo setup.... but your going to pay! And your probably not going to learn anything besides when and when not to open your wallet. Quote Link to comment Share on other sites More sharing options...
