streetshee Posted January 3, 2008 Report Share Posted January 3, 2008 hiya,ive got my lockup clutch now and im taking my cover to be modded with a clear cover,how much does it need extending? if i got the cover machined down to the widest part ,how much more would be needed to give enough clearance,and will i need to mod my right peg? sorry last question,what is everyone using for the clear cover,special tough glass or plastic? doesnt the plastic tarnish quick? thanks. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted January 3, 2008 Report Share Posted January 3, 2008 I belive they use a Lexan Plastic for the window. I can get you a measurement in a second. I will just measure from the gasket surface between the engine and cover to the inside lexan surface. I Had to grind a little material off the foot peg. josh Quote Link to comment Share on other sites More sharing options...
streetshee Posted January 3, 2008 Author Report Share Posted January 3, 2008 thanks m8...... Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted January 3, 2008 Report Share Posted January 3, 2008 Here are your measurements. Gasket surface to the end of the cast cover is 3.5 inches Gasket surface to the outside of the lexan is 4.5 inches The billit ring is aproximatley .75 inches thick with a .25 inch thick lexan cover = total thickness 1 inch Bottom of the Billit ring is 6.34 inches in diameter. Top of the ring (lexan) is 5 in 5/16th's My cover is Direct Drives Die Cast cover. You dont have to weld on any exension because they make a completly bran new cover that is extended. Then The billit ring bolts on to that cover. There is a groove machined in to the cast cover for an oring seal. There is also an oring seal inbetween the billit ring and lexan cover. I had to grind a little off the foot peg so it wouldnt hit the billit ring. You can just extend the cover straight out because it would hit the foot peg. Quote Link to comment Share on other sites More sharing options...
streetshee Posted January 3, 2008 Author Report Share Posted January 3, 2008 absolutly shit hot my friend,thankyou very much for your time and help,everything i needed to know.this world and forum needs more people like yourself. :happy: Quote Link to comment Share on other sites More sharing options...
