Throttle got STUCK......
wacko2000
Exactly what it says above...I went riding, came home washed the shee then I took her for alittle spin around the block, I shifted from 1st to 2nd and hit the throttle, before I new it I was on my ass and the shee flipped over...
Can someone tell me why this happens bc This isnt the first time the throttle has gotten stuck on me.....
Please help....This shit sucks.. My ass is killing me I cant even sit down....
if it was cold outside the water could have frozen the slides open. mine froze on me one time in the throttle assembly on the handlebars.
if you have the tors removed i heard that it will stick if you tighten the carb tops too tight.
hope that helps.
I dont no bc I rode the bike all day with no problems at all...I was thinkin that maybe some dirt or sand got in there through the air filter or something...I Zack where was you air leak? How did you find it and how did you fix it?
what sucks is that i never ride my shee with out the kill switch, I mean NEVER and the one time I dont look what happens..That switch has saved me so many times....
Zach I bent the wheelie bar, and bent an a-arm.... no biggie if you would have seen it you would understand how lucky i got...The new a-arm is in the mail already....
Mike at ASR sent me one, no questions asked, he was laughin when i told him what happened...
you got water in your carbs causing them to stick open. just take compressed air and go over the carbs really well after you wash it off
Edited by trail rider
Might be dumb, but like a tethered kill switch?
My slides kept sticking open the other afternoon I was riding. As mentioned earlier...it was probably the water/condensation in your carbs. My shee has been sitting in the open cold air due to my shop under construction. Right carb slide kept sticking every now and then so I had to blip the throttle to have it come back down. Once the moisture was gone they didn't stick anymore...
happend to me but the problem was , the carb tops came like slightly loose where the wire goes in... i was about 50mph on a gravel road with a canal next to me... I just didnt want to dump the bike in the canal trying to hold on and turn the bike off..
you can pull the slides out, take some scrotch brite or emery paper and remove the casting edges on the slides it will help them slide easier and not stick sometimes.
Some of the slide is black and some isnt, should I clean up the whole slide?
thanks guys for all the info...
The throttle cable is new...TORs is removed..
you just washed your bike, it was below freezing, and you were moving through the air. That little bit of residual water froze your throttle cable, or your slides in the carb body. How well oiled is the cable? Thats more likely the culprit.
Just dont rip your bike after you wash it, in the freezing
