tranny question
spurdy
I am in the middle of a couple of rebuilds. One is stock stroke and one is 4 mill. I have two different trannies. One is from a 1987 the other is from a 1995. I know the 6th gear is different. is there a better combo to run with the 4 mil vs. the stock stroke between one or the other ? The 4 mill will be the motor i run with the stock stroke motor as the back up.
Come on guys. Somebody must know the gearing ratio differences between the years. I am sure one ratio is preferred over the other.
I'd say run the taller gearing on the 4 mil, it'll pull it better.
As far as them being different, I'm not sure...but I do know the older ones came geared different...14/41 vs. 14/42
My man, you posted at 2:30 AM and again at 8:30...give people time to wake up and have a coffee....
Sorry, didn't mean to sound impatient but I had seen several views with no comments. :huh:
The Clymer calls out different Secondary Reduction Ratios on '87-'89 then on '90 and above which is the ratio between the front and rear sprockets if I am correct. But the gear ratio for all 6 gears indicates the same for all years. Just trying to figure out what I have in the 2 sets of transmission gears I have and why they are not the same.
Any help or ideas would be appriciated. :thanks:
Figured it out! :biggrin:
That's because a lot of us dont know. People here like to read threads because they enjoy learning.
Besides, we dont know we cant help till we view the thread. :ermm:
Edited by RagunCajun
