flattrakker Posted December 18, 2007 Report Share Posted December 18, 2007 ok i think i burnt up the clutch on my shee. was going along in 5th or 6th let off the gas, pulled in the clutch, came to a stop, dropped her in first then began to let the clutch out and it didnt grab. i was idleing in first. i got my rope out and had a friend pull me home. i drained the oil first thing and it smelled like burning nastiness. did i burn up my clutch or do somthing else? if i need a new clutch what all has to be new or what should be new? Quote Link to comment Share on other sites More sharing options...
theshee Posted December 18, 2007 Report Share Posted December 18, 2007 I bet your clutch is toasted. Call jeff at FAST and get a fast clutch. Check you inner and outer hubs for wear, check your basket and clutch cushions, if either are wore its a good time to go to a billet basket. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted December 18, 2007 Report Share Posted December 18, 2007 If you were going along it 5 or 6th and pull the clutch in and costed to a stop I bet you welded the ball and rod. Quote Link to comment Share on other sites More sharing options...
00tbanshee Posted December 18, 2007 Report Share Posted December 18, 2007 If you were going along it 5 or 6th and pull the clutch in and costed to a stop I bet you welded the ball and rod. if so that can be a fun job getting the rod out.might get lucking and come right out but i wasn't that lucky.i would invest in the pancake bearing anyway. Quote Link to comment Share on other sites More sharing options...
