jaredvh Posted December 15, 2007 Report Share Posted December 15, 2007 I recently decided to go with a K&N filter and I didn't change my jetting or anything. Yesterday I noticed it was running strange and realized it was only firing on 1 side. I checked spark and from 1 side there was nothing. I changed out the plugs and it ran fine again. Is there a possibility that because I didnt change my jetting that my banshee is running lean and burning out plugs?? THANKS Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted December 15, 2007 Report Share Posted December 15, 2007 Yes lean = hot. If it is melting the ground straps off plugs then it is way lean. You could burn holes in your pistons as well. josh Quote Link to comment Share on other sites More sharing options...
jaredvh Posted December 16, 2007 Author Report Share Posted December 16, 2007 Yes lean = hot. If it is melting the ground straps off plugs then it is way lean. You could burn holes in your pistons as well. josh The plug looked fine it just didnt spark. Quote Link to comment Share on other sites More sharing options...
xXBlessedWithDeathXx Posted December 16, 2007 Report Share Posted December 16, 2007 when i went to a open box i didnt change jets. i now foul plugs but only when its first started, warming up. i need to go smaller on my pilot. when i run the shee out the trails and all its fine. Quote Link to comment Share on other sites More sharing options...
sa3ood_banshee Posted December 16, 2007 Report Share Posted December 16, 2007 (edited) yes u have to rejet,u cant argue with anyone on the topic cuz no jetting =lean,ur engine is starving for fuel,and as jbrooker said,ur can even end up with melted pistons,so what du u think is better getting ur jetting done rite or having a top end rebuild i hope this helps Air filter Remove snorkel:1-2 sizes larger on the mains, adjust airscrews Remove airbox lid:1-2 sizes larger on the mains, adjust airscrews Add foam air filter:0-2 sizes larger on the mains, adjust airscrews Add K&N air filter:4-6 sizes larger on the mains, adjust airscrews, add one size on pilots if necessary Add 2 into 1 Foam air filter OR dual carb-mounted foam filters (removing entire airbox, NOT in addition to removing snorkel and airbox lid above):2-4 sizes larger on mains, adjust airscrews, add one size on pilots if necessary Add Dual K&N carb-mounted air filters (no airbox, NOT in addition to removing snorkel and airbox lid above):4-7 sizes larger on the mains, adjust airscrews, add one size on pilots if necessary Add Outerwear:no change i think u should even read this :biggrin: http://www.dfn.com/benkaren/jetfaq.html i thank a fellow hq member for the link sa3ood Edited December 16, 2007 by sa3ood_banshee Quote Link to comment Share on other sites More sharing options...
jaredvh Posted December 16, 2007 Author Report Share Posted December 16, 2007 yes u have to rejet,u cant argue with anyone on the topic cuz no jetting =lean,ur engine is starving for fuel,and as jbrooker said,ur can even end up with melted pistons,so what du u think is better getting ur jetting done rite or having a top end rebuild i hope this helps Air filter Remove snorkel:1-2 sizes larger on the mains, adjust airscrews Remove airbox lid:1-2 sizes larger on the mains, adjust airscrews Add foam air filter:0-2 sizes larger on the mains, adjust airscrews Add K&N air filter:4-6 sizes larger on the mains, adjust airscrews, add one size on pilots if necessary Add 2 into 1 Foam air filter OR dual carb-mounted foam filters (removing entire airbox, NOT in addition to removing snorkel and airbox lid above):2-4 sizes larger on mains, adjust airscrews, add one size on pilots if necessary Add Dual K&N carb-mounted air filters (no airbox, NOT in addition to removing snorkel and airbox lid above):4-7 sizes larger on the mains, adjust airscrews, add one size on pilots if necessary Add Outerwear:no change i think u should even read this :biggrin: http://www.dfn.com/benkaren/jetfaq.html i thank a fellow hq member for the link sa3ood Is it easy to change jets? I know nothing about doing them. Quote Link to comment Share on other sites More sharing options...
sa3ood_banshee Posted December 16, 2007 Report Share Posted December 16, 2007 (edited) yea man it verry easy and dumb once u understand were r all tha parts located,i used to nagg when mods with jetting used to show up on my mods list,its verry simple and eassy,i cant seem to find tha toturial of changing jets(with pics),i hope som1 else posts it up gd luk man sa3ood Edited December 16, 2007 by sa3ood_banshee Quote Link to comment Share on other sites More sharing options...
sheerocks Posted December 18, 2007 Report Share Posted December 18, 2007 "i think u should even read this http://www.dfn.com/benkaren/jetfaq.html i thank a fellow hq member for the link" That was an awesome article. Thanks so much for that link! Quote Link to comment Share on other sites More sharing options...
