13bturbofc Posted December 15, 2007 Report Share Posted December 15, 2007 well i have a problem with my banshee i was riding the other day and the twist throttle got stuck at full throttle so i quick turned the key off and relized some how the insides of the twist throttle came apart and im screwed i had to walk back home in the snow to get my other 4 wheeler to tow it home and i couldnt find rope so i had to use jumper cables to tow it hahahaha anyways... anyone know what could be wrong with the thing? if i twist the throttle it dosent spring back it just stays wide open..what should i do now? Quote Link to comment Share on other sites More sharing options...
Screaming Yellow Zonker Posted December 15, 2007 Report Share Posted December 15, 2007 that's in the carbs. do you have an open element air filter? mine sucked some water and froze open. Quote Link to comment Share on other sites More sharing options...
ClimbAnyHill Posted December 15, 2007 Report Share Posted December 15, 2007 Dirty carbs? Toss the twist, I have a used thumb throttle & can sell cheap! Quote Link to comment Share on other sites More sharing options...
13bturbofc Posted December 15, 2007 Author Report Share Posted December 15, 2007 that's in the carbs. do you have an open element air filter? mine sucked some water and froze open. yes i have open dual K&N elements and i was riding in the snow so i guess thats possible.. and the other day it did the same thing for a second after i washed it outside in the cold but then it came unstuck and worked ok until now.. i have the TORS removed already and i have the stock thumb throttle that i want to put back on but im not sure if i have to switch the cable to do so and im not sure what has to be done with the wires coming out of the stock thumb throttle asembaly? can i use the same cable? Quote Link to comment Share on other sites More sharing options...
nunyabinness Posted December 15, 2007 Report Share Posted December 15, 2007 no you can not use the same cable. the twist cable is longer than the thumb cable. i mean you can make it work (i did in a pinch) but it is not recommended. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted December 15, 2007 Report Share Posted December 15, 2007 Just leave the wires coming out of the tumb throttle unpluged. It is for the tors Quote Link to comment Share on other sites More sharing options...
13bturbofc Posted December 15, 2007 Author Report Share Posted December 15, 2007 ok so i just went out to the garage and to check it out and now the throttle works fine?? i guess it was frozen. so how do i prevent it from sticking again so easily i mean i only rode it for like 5 min and it got stuck. and if i do decide to go back to the thumb throttle what cable do i need to buy? just the stock cable or do i need a special one because i have the TORS removed? sorry for the newb question lol Quote Link to comment Share on other sites More sharing options...
nunyabinness Posted December 15, 2007 Report Share Posted December 15, 2007 you can get the correct cable from vito's, rockmountain atv, or F.A.S.T. (when he gets back up and running). but you have to get one for the TORSless caps. as for your freezing problem i have no idea, i have never had that problem. Quote Link to comment Share on other sites More sharing options...
ClimbAnyHill Posted December 15, 2007 Report Share Posted December 15, 2007 I'll throw the cable in for another few bux.. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted December 15, 2007 Report Share Posted December 15, 2007 ok so i just went out to the garage and to check it out and now the throttle works fine?? i guess it was frozen. so how do i prevent it from sticking again so easily i mean i only rode it for like 5 min and it got stuck. I lube my slides with Cable Life lube. It says for cables and throttle slides. Try that. Quote Link to comment Share on other sites More sharing options...
