Do you mean a stock throttle cable? If so, no, a stock cable goes into the tors, and then to the stock carbs.
I have the steel braided throttle cabel with my 2:1 it works alot better than other cables. You should look into a hone and new rings for your pistons if your running 95psi in each cyl Thats really low and is affecting preformance.
