kodie Posted December 9, 2007 Report Share Posted December 9, 2007 well i havn't started my shee in a little over a month, i went to start it up and only 1 cylinder fired up. i shut it off changed the plug and it didn't help. it ran perfect when i brought it home from hatfield then i let it sit for over a month without fireing it and now im stuck with one cyl. i live in ohio its been snowing and cold could that be a problem? and i always keep it in the garage. somone also suggested that i try to pop start it is this a good idea, anyone else got any ideas. come around noon on sunday im gonna try to pop start it. Quote Link to comment Share on other sites More sharing options...
sa3ood_banshee Posted December 9, 2007 Report Share Posted December 9, 2007 k first of all switch off ur bike lights,kill button(engine stop),turn tha key to off position,then close ur fuel cock ,then remove both plugs(put them smwere clean) and give her a couple of kicks ,u should feel that tha kickstarter kicks verry eassilly ,kick it about 6 to 7 kicks,then put tha plugs bak in and start her.try not to use choke, instead of pull starting her u can do this, tha guy who told u to pop or pull start is nows that u need to get her jugs a little cleaner,so just do this,it wont foul any plugs and it will save alot of energy, cheers :thumbsup: gd luk man btw is tha plug fouling(the one on tha not working cylinder),and are u sure that there is spark on both the plugs,could happen :shrug: sa3ood Quote Link to comment Share on other sites More sharing options...
kodie Posted December 9, 2007 Author Report Share Posted December 9, 2007 hey i did all that kicked it about 10 times with no plugs and stuff. put it back on tried kicking it. now neither fired and i kicked it about 100 times Quote Link to comment Share on other sites More sharing options...
scooter6101982 Posted December 9, 2007 Report Share Posted December 9, 2007 did u check ur plugs to see if u have spark ? if so check ur main jets the same thing happend to me i was ridin and all of a sudden lost a cylinder my main jet fell out how i dunno but it did Quote Link to comment Share on other sites More sharing options...
foxracing350 Posted December 9, 2007 Report Share Posted December 9, 2007 i had mine start running on one cylinder so i bought a new ignition coil from ricky stator and the problem was solved good luck Quote Link to comment Share on other sites More sharing options...
2strokespirit Posted December 9, 2007 Report Share Posted December 9, 2007 just open your carbs and clean them out. Quote Link to comment Share on other sites More sharing options...
WALLACE84 Posted December 9, 2007 Report Share Posted December 9, 2007 i had mine start running on one cylinder so i bought a new ignition coil from ricky stator and the problem was solved good luck Ditto. Thats exactualy what I was going to say. Try that Quote Link to comment Share on other sites More sharing options...
kodie Posted December 10, 2007 Author Report Share Posted December 10, 2007 hey im getting spark to my plugs now what do i check? Quote Link to comment Share on other sites More sharing options...
scooter6101982 Posted December 10, 2007 Report Share Posted December 10, 2007 check ur main jets like i said b4 Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted December 10, 2007 Report Share Posted December 10, 2007 Shoot a little carb cleaner in each plug hole and put plugs in and fire it up. If I let mine sit for a lttle bit and it is cold it only starts up on one cylinder. A little snap of the throttle brings both cylinders on line. Quote Link to comment Share on other sites More sharing options...
sa3ood_banshee Posted December 11, 2007 Report Share Posted December 11, 2007 WTF!!!!!!!! :geek: ,is there a spark or no?? wat plugs r u running???,are ur pluggs gapped to spec??? sa3ood Quote Link to comment Share on other sites More sharing options...
