foxracing350 Posted December 9, 2007 Report Share Posted December 9, 2007 will yfz 450 a arms bolt up to a banshee or is there modification that needs to be done? Quote Link to comment Share on other sites More sharing options...
peterlocal22 Posted December 9, 2007 Report Share Posted December 9, 2007 (edited) will yfz 450 a arms bolt up to a banshee or is there modification that needs to be done? the uppers bolt right but but the lowers need to be modified a little. they need to be cut in two places and you should add spacers to make it fit real nice. you will also need longer tie rods. heres the link to a very good instructional topic on installing 450 a arms onto a banshee: http://www.bansheehq.com/forums/index.php?...&hl=yfz+450 one side note, if you install 450 a arms i would highly recomend you also install 450 spindles. the yfz spindles will set your bike at the correct angles and also give you alittle more shock travel. heres the link to more info on the spindles: http://www.bansheehq.com/forums/index.php?...hl=yfz+spindles i ran my banshee w yfz 450 a arms w stock banshee spindles and with 450 spindles and its a night and day difference on the ride as well as wearing of parts. hope this helps thanks peter Edited December 9, 2007 by peterlocal22 Quote Link to comment Share on other sites More sharing options...
foxracing350 Posted December 9, 2007 Author Report Share Posted December 9, 2007 the uppers bolt right but but the lowers need to be modified a little. they need to be cut in two places and you should add spacers to make it fit real nice. you will also need longer tie rods.heres the link to a very good instructional topic on installing 450 a arms onto a banshee: http://www.bansheehq.com/forums/index.php?...&hl=yfz+450 one side note, if you install 450 a arms i would highly recomend you also install 450 spindles. the yfz spindles will set your bike at the correct angles and also give you alittle more shock travel. heres the link to more info on the spindles: http://www.bansheehq.com/forums/index.php?...hl=yfz+spindles i ran my banshee w yfz 450 a arms w stock banshee spindles and with 450 spindles and its a night and day difference on the ride as well as wearing of parts. hope this helps thanks peter thanks Quote Link to comment Share on other sites More sharing options...
96bansheeboi Posted January 31, 2009 Report Share Posted January 31, 2009 thanks im new here and did the install i have a quick question ....i used raptor shocks and it seems to sit low to me ...is it possible to get a few side and front pics of someone doing the install...raptor shocks are longer than yfz ones but it just looks weird to me thanks ill post pics later Quote Link to comment Share on other sites More sharing options...
