WTF still no spark!
pweezy42
ok so now i have changed the stator, coil, cdi, on/off switch, bypassed the ignition, and changed the wire harness., sanded all ground points! :mad: and at first i got spark but it was on and off then it just went to no spark again :mad: WTF :mad: WTF :mad: WTF :mad: WTF :mad: :mad: :mad: :mad: im ready to smash the shee! any other suggestions other than to take it to a shop and get charged out the wazoo for it?? :mad: :mad: :mad: :mad: :mad: :mad: :mad: :mad:
is the flywheel rusty?? inside or out? clean the little pads on the out side of the fly wheel where the pick up reads to fire the motor!
Do you have a ground going from the engine to the chassis?? is the frame painted or powder coated?? sand all the powder coast off of where the egine mounts go threw. ( I know it sounds dumb but I have seen it cause no fire!)
Did you replace the cdi and stator with known good parts?? have you ohmed the stator with a meter?? un plug it and read the stripped wires first, then the soild wires. they should be within 100 ohms of one another. ( example, one set is at 17 ohms, other set of wires is at 117 ohms. give or take a few) if you bypassed the key, did you reconnect the wires to one another? seen that one a few times too!
is the pick up on the stator set at .018-.020??
report back and we will go from there.
Edited by badassbanshee479
no sand around here and we did try the fly wheel swap both ways his kicked over mine nadda :down::confused: trust me we did all of it but nothin its sad to say but im gonna end up taken it to a shop for them to charge the fuck out of me but im at that point missed the snow storms the last 2 weeks...oh ya and im in Scranton PA just a couple min ride from MI :biggrin: :biggrin: :biggrin:
