Jetting Problem..
wacko2000
So I have alittle jetting issue, I have a slight bog in 1st and 2nd and 3rd very little and then clears up, more so in 1st and 2nd...
350main
30pilot
stock needle clip in middle
2 turns on air screw
Im a sea level
air box no lid, vented out
Here are some mods that I have.
T5's
v-force reed
noss head 21cc domes
hot mx port
Any other info you need, just let me kno..
__________________
wacko you sure your not lean on the needle? if you had all the work done and didnt change anything id think your leanis it the 1 1/4 to 1 3/4 throttle position?
Can you be more specific.. I dont really understand that..
" If you had all that work done and didnt change anything"?
Before i sent my motor out it was completlel stock, stock bore with T5's and v-force reeds
310 main
25pilot
needle in the middle..
Now
350 main
30pilot
2 turns on the air screw
Call Jim at Passion and see what he recommends. He will know better than anyone where his motor likes fuel.
The pilot jet and air screw work together.
The pilot jet allows fuel into the low speed circuit, the air screw is adjusted to mix air with that fuel supplied by the pilot jet.
Pilot air screw effect idle to just past 1/8 throttle....that's it.
I think 30 pilot is too big for a motor still running an airbox, but....if the Passion motor likes a TON of fuel at lower RPMs, then it could be ok.
I think it's too rich off idle, by the time it gets to the needle (past 1/8 throttle) it is still cleaning itself out. Once you get into higher gears/RPMs it is cleaned up and starts to pull....
PLEASE, only adjust one circuit at a time, pilot/air screw, needle or main.
Changing multiple circuits at the same time will only complicate things.
Start by putting a stock pilot in there at turning the air screw out 1.0 turns. Usually too much fuel causes a bog.
When it's lean, it'll "surge" or raise the RPM, it'll sound like it wants to rev but no power....
Tell you what, there's a couple great jetting thread how to's for stickys at the top of this forum. Read them, twice....they could probably answer all of your questions and guide you best.
