foxracing350 Posted December 3, 2007 Report Share Posted December 3, 2007 i am putting my banshee away for the winter and was wondering if there is anything i should do to it before i put it away Quote Link to comment Share on other sites More sharing options...
fixitrod Posted December 3, 2007 Report Share Posted December 3, 2007 Kinda of like a boat... You don't want any water anywhere. I normally just park it right or wrong... lol Here are some steps that will insure good storage in the cold. Make sure water is 50 percent antifreeze. (Don't need cracked cylinders) Put one teaspoon of 2 stroke oil or fogging oil in each cylinder.(keeps cylinders nice) Put fill the tank full(prevents moisture) put fuel stabilizer in. Turn off fuel and run fuel out of carbs (prevents sticky old fuel from clogging). Tip the quad up on the grab bar for a few minutes to let the water run out of the frame. It does build up. Open the stator cover to let any water run out that may have collected from the summer. Grease all zerks to put water and dirt out. Change the tranny oil in case there is water in there. That's all I can think of right now. There may be more but it's a start Quote Link to comment Share on other sites More sharing options...
foxracing350 Posted December 3, 2007 Author Report Share Posted December 3, 2007 thanks Quote Link to comment Share on other sites More sharing options...
