lean on the pilot
flattrakker
im lean on my pilot jet.. but for now i want to get it started and running and not so worried about bogg off idle.. im having a hard time getting her started cuz shes lean.. how should i go about starting it? like.. full choke little gas.. hlaf choke no gas.. no choke full gas.. i think you get what i mean.. also i need part numbers for aftermarket pilots jets..
How do you know your lean? What size are you running now?
nope... how do i adjust the floats?
Did start okay when it was warmer out? Have you done anything to the carbs? Does it start if you hold the throttle wide open as opposed to at idle or just above. You could adjust your pilot screw in to richen a bit. Try it at 1/4 turn from seated. 1/2... 3/4 ... if it starts they are lean. If you get over two turns out and it starts they are rich. Cold weather does create a lean condition. The screw adjust the amount of air that comes in.
If it won't start at all it may not be jets at all. :blink: Make sure the choke tube is between the carbs too... start simple.
