01CandyBlue Posted November 29, 2007 Report Share Posted November 29, 2007 I am debating on whether to buy the YFZ450 shocks or spend the extra coin on some nicer ones. YFZ shocks seem to be about 200-250. I found remote rezzi triple works rebuilt by tcs for 330. Am I going to see that much of a difference in the perfromance? I woul think I would but this build is on a budget so I am scrimping where I can. I am not a greta rider or anything, just working my way up and doing the best I can. I mostly ride dunes, and jump but not too far. Thanks for any help!!! Quote Link to comment Share on other sites More sharing options...
Michael Jackson Posted November 29, 2007 Report Share Posted November 29, 2007 i say go with the works, i have them and they ride 10 times better than any 450 shocks i have ridden, if you can get them for only $100 more than the 450 shocks, DO IT, 450 shocks are longer, will make your front end sit up higher, unless you use the 450 arms then it will sit very low, get the works that are built for the banshee, they are 100 times better than stock and 10 times better than 450 shocks, ive read about too many people buying those 450 shocks and puttin them on their banshees and regretting it, just spend the extra bit of cash and get the works Quote Link to comment Share on other sites More sharing options...
01CandyBlue Posted November 29, 2007 Author Report Share Posted November 29, 2007 Well I jumped, spent 600 for his wicked arms and brake lines and tie rods, also got his works tripple rates with resevoirs, he just had tcs go through and rebuild them about 10 months ago. We will see how it goes. Can I powdercoat the springs without hurting them? They are a little dinged. Quote Link to comment Share on other sites More sharing options...
Michael Jackson Posted November 29, 2007 Report Share Posted November 29, 2007 cool im sure you will love them, anyhting is better than the stock crap, as far as powdercoating springs, im pretty sure you can, but dont quote me on that, baking might hurt them , im not positive Quote Link to comment Share on other sites More sharing options...
dragbanshee Posted November 30, 2007 Report Share Posted November 30, 2007 Well I jumped, spent 600 for his wicked arms and brake lines and tie rods, also got his works tripple rates with resevoirs, he just had tcs go through and rebuild them about 10 months ago. We will see how it goes. Can I powdercoat the springs without hurting them? They are a little dinged. I just put that same setup on my 97 without the rezzies, your not going to regret it , best upgrade. Quote Link to comment Share on other sites More sharing options...
fixitrod Posted November 30, 2007 Report Share Posted November 30, 2007 Well I jumped, spent 600 for his wicked arms and brake lines and tie rods, also got his works tripple rates with resevoirs, he just had tcs go through and rebuild them about 10 months ago. We will see how it goes. Can I powdercoat the springs without hurting them? They are a little dinged. You won't regret the shocks. If you do, then have the re-adjusted. That will be the issue if you have one. I've seen the springs powder coated and chromed but don't know if the add a flex to the powder. Quote Link to comment Share on other sites More sharing options...
Shane Posted November 30, 2007 Report Share Posted November 30, 2007 You won't regret the shocks. If you do, then have the re-adjusted. That will be the issue if you have one. I've seen the springs powder coated and chromed but don't know if the add a flex to the powder. Powdercoating is what is on them now and will be just fine. The TCS rebuild to the works shock is a great set-up because Todd changes the valve itself. Quote Link to comment Share on other sites More sharing options...
peterlocal22 Posted November 30, 2007 Report Share Posted November 30, 2007 depends if you have stock or aftermarket a arms. Quote Link to comment Share on other sites More sharing options...
