TexasBansheeMan Posted November 15, 2007 Report Share Posted November 15, 2007 (edited) I have a 2001 banshee cool head, 19cc domes, .20 over, dune port, 30 mm oko, VF'2, toomy T5's, 5+ timing, +10/-10 plate, What do I need to do to set my bike up for methanol? I only want to do this because i have easy acess to ALOT of it. Is it possible to run this in my bike? What else do you recomend? Thanks! :biggrin: " I WANNA GO FAST MOMMY!"R.B. Edited November 15, 2007 by TexasBansheeMan Quote Link to comment Share on other sites More sharing options...
dajogejr Posted November 15, 2007 Report Share Posted November 15, 2007 If you got rid of those geckos....it would feel like you already had Alky.... bump the timing to 7, drill the main jets and dump tubes out, larger pilots jets and install power jets in the carbs. You'd be wasting your money converting those carbs to alky....get a new set. 35PWK, 34PJs or 35TM carbs would be fine for that motor.... Is your crank already trued and welded, as well? And get rid of the airbox and get pod filters. Quote Link to comment Share on other sites More sharing options...
TexasBansheeMan Posted November 15, 2007 Author Report Share Posted November 15, 2007 I put the chop on the Air box :biggrin: custon 1 into 2 intake its all open with a k&n with outerwear 30mm pods are useless :biggrin: Quote Link to comment Share on other sites More sharing options...
dajogejr Posted November 15, 2007 Report Share Posted November 15, 2007 For alcohol, 30mm carbs, in my opinion..yes. And do it right, get two pods. I know people that have chopped the airbox off except where the filter is and the boots are...still have sealing problems... Quote Link to comment Share on other sites More sharing options...
TexasBansheeMan Posted November 15, 2007 Author Report Share Posted November 15, 2007 If i change to running methanol will I still be able to play in the trails Like I like to? Or will this make it a drag and cool type bike? Quote Link to comment Share on other sites More sharing options...
06BaNsHeE Posted November 15, 2007 Report Share Posted November 15, 2007 If i change to running methanol will I still be able to play in the trails Like I like to? Or will this make it a drag and cool type bike? It will be better for trails because the bike will run cooler.But it burns twice as fast.Ill be running alky on my bike and Ill be riding trails.But everyone on here will probably bash me for saying im riding a alky cub in the trails.lol. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted November 15, 2007 Report Share Posted November 15, 2007 It will be better for trails because the bike will run cooler.But it burns twice as fast.Ill be running alky on my bike and Ill be riding trails.But everyone on here will probably bash me for saying im riding a alky cub in the trails.lol. No...as long as you are VERY close to the truck (which...when I ride trails I like to go on a 30 or 40 mile loop)... I think you should keep alky at the dunes and the track, people use alky yes, because it runs cooler and it makes more power. Get better pipes, porting and carbs before I'd use Alky for the trails.... Quote Link to comment Share on other sites More sharing options...
TexasBansheeMan Posted November 15, 2007 Author Report Share Posted November 15, 2007 I got 7,000 gal at work and my boss said "take all you want its not like your running your car on it" and just laughed and walked away. So the fast burn is ok it wont cost me shit. What kinda pipes and port do you recomend? Quote Link to comment Share on other sites More sharing options...
06BaNsHeE Posted November 15, 2007 Report Share Posted November 15, 2007 No...as long as you are VERY close to the truck (which...when I ride trails I like to go on a 30 or 40 mile loop)...I think you should keep alky at the dunes and the track, people use alky yes, because it runs cooler and it makes more power. Get better pipes, porting and carbs before I'd use Alky for the trails.... How long of non-stop riding you thin i can go with a 4mill Drag Ported Cub on 39pwks.Im hoping like 1 hour?Or will I have to take my 54 gallon drum everyride lets say for a 14 hour riding weekend? Quote Link to comment Share on other sites More sharing options...
TexasBansheeMan Posted November 15, 2007 Author Report Share Posted November 15, 2007 I just wanna go fast. Hell its already fast but I want FAST. maybe I should just send my toy to them. humm :yes: maybe so. Quote Link to comment Share on other sites More sharing options...
06BaNsHeE Posted November 15, 2007 Report Share Posted November 15, 2007 I just wanna go fast. Hell its already fast but I want FAST. maybe I should just send my toy to them. humm :yes: maybe so. Looks like your ready for Cubs and a 4mill Crank!!!No need for alky with that setup if you just wanna go fast Quote Link to comment Share on other sites More sharing options...
dajogejr Posted November 15, 2007 Report Share Posted November 15, 2007 How long of non-stop riding you thin i can go with a 4mill Drag Ported Cub on 39pwks.Im hoping like 1 hour?Or will I have to take my 54 gallon drum everyride lets say for a 14 hour riding weekend? I get about 10 to 15 passes on a full stock tank at 300 foot a time. That's pushing the bike to the starting line, firing it up to warm it up...staging, WOT for 4 or 5 seconds, then idling back the return lanes to the pits or to line up and race again... So....yeah, it's pointless for trails. Quote Link to comment Share on other sites More sharing options...
TexasBansheeMan Posted November 15, 2007 Author Report Share Posted November 15, 2007 Is there that BIG of a diference in a 4mm vs stock with work in sig. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted November 15, 2007 Report Share Posted November 15, 2007 As long as you get the porting to match the longer stroke....7%, give or take. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted November 15, 2007 Report Share Posted November 15, 2007 I get about 10 to 15 passes on a full stock tank at 300 foot a time. That's pushing the bike to the starting line, firing it up to warm it up...staging, WOT for 4 or 5 seconds, then idling back the return lanes to the pits or to line up and race again... So....yeah, it's pointless for trails. 15 passes at 300 feet is 4500. 3.5 gallons per mile. Not Bad :biggrin: Quote Link to comment Share on other sites More sharing options...
