bbcmudtruck Posted November 7, 2007 Report Share Posted November 7, 2007 I am putting on a new stock swing arm. What all do I need for bearings, seals etc. Who has the kit I need. Also is there some way to gusset or reinforce a stock swinger? Thanks guys Ryan Quote Link to comment Share on other sites More sharing options...
NYUK Posted November 7, 2007 Report Share Posted November 7, 2007 pivotworks has the kit for the pivot tube and the carrier. i would recommend drilling and tapping a grease zerk in both. the stock swinger is a big heavy mess of pigeon shit yamaha welds.i wouldnd`t go welding and grinding on it unless you are a professional. i have put many a banshee swinger through massive abuse. the only thing that ever failed was the bearings. Quote Link to comment Share on other sites More sharing options...
bbcmudtruck Posted November 7, 2007 Author Report Share Posted November 7, 2007 I appriciate the info nyuk. Where at on the pivot tube does the zerk need to be? Obviously where I can reach it, but is there prefered placement? As far as bending the swinger, I think its just bent where the bearing carier bolts up to it. I didnt want to try and bend back into shape, thinking that it would just happen again. Also, do you have any chain tensioners? Mine are getting a little ugly. Quote Link to comment Share on other sites More sharing options...
NYUK Posted November 7, 2007 Report Share Posted November 7, 2007 yes i have a set of chain tensioners.15 shipped. put the zerk where it can easily be greased. Quote Link to comment Share on other sites More sharing options...
