HKIC Posted October 28, 2007 Report Share Posted October 28, 2007 Hey guys, I just finished putting my motor back together but the clutch doesnt feel like its engaging. When i pull it back i cant tell if its engaging, should i be able to? The spring is on right thanks Quote Link to comment Share on other sites More sharing options...
dajogejr Posted October 28, 2007 Report Share Posted October 28, 2007 Hey guys, I just finished putting my motor back together but the clutch doesnt feel like its engaging. When i pull it back i cant tell if its engaging, should i be able to? The spring is on rightthanks More than likely, it's not adjusted properly, or not seated right in the basket/hub. Quote Link to comment Share on other sites More sharing options...
HKIC Posted October 28, 2007 Author Report Share Posted October 28, 2007 How would i adjust it? inside the clutch cover i dont know what to adjust. all the clutch plates are in correct, i followed the clymers but im lost after that Quote Link to comment Share on other sites More sharing options...
drpimper Posted October 28, 2007 Report Share Posted October 28, 2007 The center Phillips head screw loosing the nut on it and turn the Phillips Quote Link to comment Share on other sites More sharing options...
dajogejr Posted October 28, 2007 Report Share Posted October 28, 2007 Loosen the cable all the way. With your finger, you should be able to push the engagment lever on the left side (shifter side) on top of the crank case...and it should stop...when the arrows line up. If not, you loosen the locknut in the middle of the clutch basket, and turn the phillips screw in or out until the arrows line up by just pressure from your hand. Lock it back down, then it's adjusted. Give yourself about a nickel or slightly more freeplay in between the perch and the lever before you can feel the lever try to disengage the clutch. Quote Link to comment Share on other sites More sharing options...
drpimper Posted October 28, 2007 Report Share Posted October 28, 2007 Loosen the cable all the way.With your finger, you should be able to push the engagment lever on the left side (shifter side) on top of the crank case...and it should stop...when the arrows line up. If not, you loosen the locknut in the middle of the clutch basket, and turn the phillips screw in or out until the arrows line up by just pressure from your hand. Lock it back down, then it's adjusted. Give yourself about a nickel or slightly more freeplay in between the perch and the lever before you can feel the lever try to disengage the clutch. Well said :thumbsup: Quote Link to comment Share on other sites More sharing options...
HKIC Posted October 28, 2007 Author Report Share Posted October 28, 2007 OK, thanks guys. you saved me, im tryna break my motor in today :cool: Quote Link to comment Share on other sites More sharing options...
