Jetting suggestions
Fre530d
Hello Guys
I installed my FAST ported cilinders last week. It is a agressive dune port.
I started with 360 mains , clip 4th pos., air screws 1,5 turns out.
Mod's are 20 cc domes Noss coolhead, trinity stage 4 pipes, V force 3 and POD filters.
It was bogging a little in the midrange but pulled out well from the lower range.
Now I've putten in 330 mains , rest is the same, the bogging stopped but when i am driving slowly
let's say 5000 rpm in 6th gear and I push the throttle , it revs super slowly , it takes ages to get to the
powerband. The engine feels like it's low on compession but it isn't.
Am i running too lean? I thought it was my compression but the compr is 170 Psi what's fine
at sea level I think. Any sugg?
Fred
I would put those 360's back in for the first chop. That's what he put in mine and it was just a hair lean, or nervously spot on!! I put in 370's and didn't notice a difference except for a better ring on the plugchop. That was at 800' and about 80F out. Colder now, need bigger mains!!!!!!!!
I know of guy that runs 400 mains in one of Jeffs Dune ported motors, and it screams. Not sure of the pilots or needle clip position.
The biggest main that Jeff has sent me is 360 so I think that's the one Jeff suggested me.
Thx for all the answers.
Maybe Jeff can shime in?
WFG
Fred
Fred do you have stock pilot or 27.5?? If stock pilot your air screw is too far out. Try 1/2 turn. May need to play with clip position on needle. ALWAYS start fat and work your way down. If stock needle i would think in the middle would work but we have had some that had to go lean (clip to top).
I would say keep it in the 4th clip down for now, try the 1/2 turn out and see if it will work. You may be fine with what you have .
Yes we stock ALL jets!!!
  • 3 weeks later...
