zach45 Posted October 26, 2007 Report Share Posted October 26, 2007 few questions...with the brake lines i put both the lines on the one nut comming from the rezzy? any other tips on adjusting the castor and chamber? Quote Link to comment Share on other sites More sharing options...
Washburn Posted October 29, 2007 Report Share Posted October 29, 2007 Just adjust them to 5/8ths set everything sit on it get the feel for it ride it around and reset if needed. Thats the thing with adjustable racing arms and shocks you need to put the time in adjusting them to get them to ride 100%. Way to many people just bolt them up set them once and go. If thats the case recs and no adjustments are the way to go cause its a waste of money having all of those options and not useing them to their full potential. I cant wait to ride mine but I know its going to be at least a month of tuning and adjusting before I get everything rite. Quote Link to comment Share on other sites More sharing options...
wacko2000 Posted October 29, 2007 Report Share Posted October 29, 2007 whats up Zach I just installed my brake lines today also. I installed both lines to that one bolt.. I bleed my back brake and its fine, Im having a problem with the front brake lines, I cant get anything out of them, must have bleed each one 100times... Did you get your setup yet? Quote Link to comment Share on other sites More sharing options...
wacko2000 Posted October 29, 2007 Report Share Posted October 29, 2007 Just adjust them to 5/8ths set everything sit on it get the feel for it ride it around and reset if needed. Thats the thing with adjustable racing arms and shocks you need to put the time in adjusting them to get them to ride 100%. Way to many people just bolt them up set them once and go. If thats the case recs and no adjustments are the way to go cause its a waste of money having all of those options and not useing them to their full potential. I cant wait to ride mine but I know its going to be at least a month of tuning and adjusting before I get everything rite. Hey what do you have to set to 5/8ths.. Im trying to set mine also... Quote Link to comment Share on other sites More sharing options...
ClimbAnyHill Posted October 29, 2007 Report Share Posted October 29, 2007 I used a bleeder on those fronts.. Wen't back back n forth between both calipers till all the air bubbles were gone! Took a while but got it done! Quote Link to comment Share on other sites More sharing options...
wacko2000 Posted October 29, 2007 Report Share Posted October 29, 2007 I used a bleeder on those fronts.. Wen't back back n forth between both calipers till all the air bubbles were gone! Took a while but got it done! Where can I get a bleeder? Yea it was def starting to annoy me today.. I caliper where completely empty,bc i rebuilt them is that why it is taking so long bc the calipers have to fill up also.. I saw alot of bubble coming out while I was doing it..I didnt have to fill it that much, that was one of my concerns, felt like i wasnt getting anywhere.. Quote Link to comment Share on other sites More sharing options...
ClimbAnyHill Posted October 29, 2007 Report Share Posted October 29, 2007 I got mine from Rockymountainatv.com Local bike shops usually carry them too! Quote Link to comment Share on other sites More sharing options...
wacko2000 Posted October 29, 2007 Report Share Posted October 29, 2007 I got mine from Rockymountainatv.comLocal bike shops usually carry them too! Thanks I will check it out tom.. Quote Link to comment Share on other sites More sharing options...
zach45 Posted October 31, 2007 Author Report Share Posted October 31, 2007 W we might have to go somewhere and get these front ends setup... mine should be here earily next week... going down to exit 69 sunday.. Quote Link to comment Share on other sites More sharing options...
Ride-Red Posted November 1, 2007 Report Share Posted November 1, 2007 No need for a bleeder, get a large seringe or baster- fill it full of fluid, get some vacuum/fuel line hook it from the seringe to the caliper and squeeze it in and up to the rezivoir. Fool proof. To set the front end- get two identical framing squares. Measure the diameter of your tires with the outside shortside of the square starting from the outside corner and mark the overall diameter 18 - 22 inches and the center 9 - 11 inches. Yank the rims off and sit the bike on jack stands or equal height blocks and have someone your weight sit on it. Turn the squares over so the long ends are pointing in at each other and not out away from the sides. Line the center 9-11 inch mark up with the center of the spindle nut. Take a measurement across front of the bike ( the short side should be parallel to the ground crossing the 9 oclock and 3 oclock on the hub and the long sides parallel to the ground crossing in front of the bumper) mark one of the squares where the other one ends. Do the same thing for the back side measurement. the backside measurement should be 1/2" to 3/4" less then the front. Make sure your bars are straight before you even start- you will have to keep correcting the centering by making sure both squares have the same measurement from hub to center of bike. It takes 5 min once you get the knack. The camber is a matter of preference- I keep mine 1" in on top on my R. Careful with those Amer Stars- the threaded heims bend real easy, they wear quick and get sloppy and rattly. Quote Link to comment Share on other sites More sharing options...
zach45 Posted November 1, 2007 Author Report Share Posted November 1, 2007 lost me there... clif notes on how to set them up... Quote Link to comment Share on other sites More sharing options...
wacko2000 Posted November 1, 2007 Report Share Posted November 1, 2007 o0o boy Zach....I just got a headache reading alll that above.... Quote Link to comment Share on other sites More sharing options...
ClimbAnyHill Posted November 1, 2007 Report Share Posted November 1, 2007 going long travel on those +3's? What shocks you slapping ont there? Quote Link to comment Share on other sites More sharing options...
zach45 Posted November 2, 2007 Author Report Share Posted November 2, 2007 no LT... i wish... just not spending 1700 on a front end... going to use the 450's till i can get a nice set of elkas/works somehting along those lines.. Quote Link to comment Share on other sites More sharing options...
Michael Jackson Posted November 2, 2007 Report Share Posted November 2, 2007 (edited) man u shoulda went with the roll design lobo / elka front end.. only $2700 man... then all u need is the long travel rear linkage /shock/skid plate AND dont forget the shock cover,for only another $1600 or so! its a steal at this price! haha http://cgi.ebay.com/ebaymotors/Roll-Design...VQQcmdZViewItem http://cgi.ebay.com/ebaymotors/Elka-Rear-S...1QQcmdZViewItem aww shit look, onlyt $1200+ for the rear... only about $4000 in all!!... whos got this setup, front and rear end? anyone? Edited November 2, 2007 by Michael Jackson Quote Link to comment Share on other sites More sharing options...
