Parts F/S
Pro Elite Nerf Bars $75
IMS Tank ( NO cap or petcock ) $150
Aluminum Bumper $50
Stock Coil $40
Lower Motor Mounts $15
Eibach 8 Inch Coil over Rear Spring 0800-225-0375, Used but good condition. $30
If you wish to use Paypal You add 3% for fees. If not I will take money orders.
All parts plus shipping.
Edited by Bansh-eman
Which tank is it (size)?
the tank is the 4gal IMS tank. also the tank has been fitted for a pingle valve. only means the plstic bridge in the center was cut out. You can still use the stock petcock just thought you might want to know it was removed.
What did you use that spring on Bansh-eman?
the spring was on my Works Rear but i had to up the spring becasue i gained weight. i used it when i was 180.
