Bobby Banshee Posted October 24, 2007 Report Share Posted October 24, 2007 Are the carb sync tools worth messing with??? Is someone better off doing it by sight and ear. Quote Link to comment Share on other sites More sharing options...
XxMeltIcexX Posted October 24, 2007 Report Share Posted October 24, 2007 Man this comes up alot. I think they are junk, alot of people will disagree with me. Unless you dont know how to screw with carbs or have very little knowledge with Banshees dont get one. Whats the difference when your WOT, which you should be Quote Link to comment Share on other sites More sharing options...
hyperlite33 Posted October 24, 2007 Report Share Posted October 24, 2007 In my opinion this is one of the greatest tools I have used on my banshee. I borrowed one from a friend, now I want to buy one myself. You can tune the carbs really nat's ass close with this thing! Quote Link to comment Share on other sites More sharing options...
lonestar Posted October 25, 2007 Report Share Posted October 25, 2007 (edited) The one that jeff@ F.A.S.T sells great little tool. Once you set your carbs up Index your slide screw with white paint (bench mark) Youll always have a reference point. Edited October 25, 2007 by lonestar Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted October 25, 2007 Report Share Posted October 25, 2007 Man this comes up alot. I think they are junk, alot of people will disagree with me. Unless you dont know how to screw with carbs or have very little knowledge with Banshees dont get one. Whats the difference when your WOT, which you should be I 100% Disagree... Having your carbs out of sync can be the culprit of many problems.. and its just a fact that you will not get your carbs synced by eyeing it... you may get lucky and get them close but looking at a gap thats .1 inch differance your eye will not see. but the tool will messure the differance in the amount of air passing. its by far a nessessary tool of anyone with a multipul carb motor Quote Link to comment Share on other sites More sharing options...
LiftdT4R Posted October 25, 2007 Report Share Posted October 25, 2007 I 100% Disagree... Having your carbs out of sync can be the culprit of many problems.. and its just a fact that you will not get your carbs synced by eyeing it... you may get lucky and get them close but looking at a gap thats .1 inch differance your eye will not see. but the tool will messure the differance in the amount of air passing. its by far a nessessary tool of anyone with a multipul carb motor Listen to this dude! They are the shit, I thought I was really fuckin good, then I bought a carb tool to check it out, turns out I was off by a lot, the bike ran a lot stronger, and I expect the build on the motor to last a lot longer too. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted October 25, 2007 Report Share Posted October 25, 2007 Saying you can sync your carbs perfectly without this tool is like saying you can torque your cylinder head down by feel without a torque wrench... I would consider myself pretty good with carbs, setting them up, etc. I have sat there for 1/2 hour eyeballing carbs idle, movement, etc. This takes all the guess work out of it...period. And all I do is idle, rev it a few times and then go WOT for a few seconds...and I still use it. Quote Link to comment Share on other sites More sharing options...
lonestar Posted October 25, 2007 Report Share Posted October 25, 2007 The carbs have to be in-sync to jet the bike correctly. I use to use a drill bit to set the hight on the slides. To get a bench mark. It's not the wright way. Or accurate way. Jeffs tool works off the CFM per cylinder. Thats correct way. BIG defferance. Quote Link to comment Share on other sites More sharing options...
Animalman294 Posted October 25, 2007 Report Share Posted October 25, 2007 Yeah, I bought one and I think it works great. It takes all the guess work out of it and it is a lot faster to do the job. Jeff told me that it was a good investment and I trust what he says and also gives me piece of mind to know that the CFM's are dead nuts on............... Quote Link to comment Share on other sites More sharing options...
FireHead Posted October 25, 2007 Report Share Posted October 25, 2007 I 100% Disagree... Having your carbs out of sync can be the culprit of many problems.. and its just a fact that you will not get your carbs synced by eyeing it... you may get lucky and get them close but looking at a gap thats .1 inch differance your eye will not see. but the tool will messure the differance in the amount of air passing. its by far a nessessary tool of anyone with a multipul carb motor I agree. :thumbsup: Quote Link to comment Share on other sites More sharing options...
chevrolet banshee Posted October 25, 2007 Report Share Posted October 25, 2007 Well i just put a set of Kehin 35 mm carbs and didn't use on of your fancy carb sync tool and it runs just fine the jetting i perfect. saved me $50 Quote Link to comment Share on other sites More sharing options...
FireHead Posted October 25, 2007 Report Share Posted October 25, 2007 Well i just put a set of Kehin 35 mm carbs and didn't use on of your fancy carb sync tool and it runs just fine the jetting i perfect. saved me $50 It's not really about jetting...................it has do with ensuring the carbs are both in the same position at any given point in the slide travel. :geek: Quote Link to comment Share on other sites More sharing options...
dajogejr Posted October 25, 2007 Report Share Posted October 25, 2007 Well i just put a set of Kehin 35 mm carbs and didn't use on of your fancy carb sync tool and it runs just fine the jetting i perfect. saved me $50 It's because the Boost Bottle gave you the Force....the force is strong in this one... As said, it doesn't do a thing for jetting, it's about two carbs feeding two cylinders the same amount of fuel/air at the same time. Quote Link to comment Share on other sites More sharing options...
CadillacBanshee Posted October 25, 2007 Report Share Posted October 25, 2007 Where can i get one? I think im gonna invest in one. Quote Link to comment Share on other sites More sharing options...
fastbanshee8 Posted October 25, 2007 Report Share Posted October 25, 2007 Where can i get one? I think im gonna invest in one. Jeff @ Fast Racing has them. Click on his add, and it will take you to his site, so you can get all the info. Quote Link to comment Share on other sites More sharing options...
