I need help locating a Big Bore Kit.
fracas
I just bought a 01 Banshee from a Friend. It has burnt rings and need to be replaced. I was told that the Shee has a Viseeto 402cc Kit. I have never heard of this Brand. Can anyone point me in the right direction to where I can find a set of rings for this. Or can I just pull the head off and Mic the clearences and get new rings? Also Im not sure if I can usea stock OEM gasket kit of not.
All help will be helpful for me.
Here is another question. When running the 404cc big bore kit what Gas are you guy using?
I thought it would need some race fuel. But my buddy said he was using 93 with some Octain booster.
It depends on what domes and compression you are running....
Octane booster is a joke... either run race fuel or a mix of race/pump fuel IF your motor needs it.
Well From what I see on the motor it still has the Stock Head on the cylinders. Not sure on the Compression at all. But it does have the 404cc kit. Not sure on the bore either. I went out this morning and fired the bike up. Runs fine now. But last sunday it was firing on 1 cylinder. I think the ring got hung up. So Im gong to pull the topend today and check everything and maybe do some file work and see if it helps.
