Tim Potteiger Posted September 26, 2008 Report Share Posted September 26, 2008 Your domes may be damaged. If you want to send them, and the head if you want, to me I will check them out. -David I can do that, or if you are willing, I can even bring it out since I live in Prattville, you are just right down the highway 20 minutes. I have several sets of extra domes I can try out, Gary at K&N said the domes weren't damaged yet from detonation and looked okay, but who knows. They aren't that old either, since the last set peeled the o-ring groove off, I replaced them. Thanks David Quote Link to comment Share on other sites More sharing options...
sinisterboo Posted September 26, 2008 Report Share Posted September 26, 2008 see how us okies do it? thats service after the sale for ya! Quote Link to comment Share on other sites More sharing options...
Tim Potteiger Posted September 26, 2008 Report Share Posted September 26, 2008 This time it might not be leaking in the head. Since the problem sounded like lack of circulation also, I checked the brand new pro design billet water impeller I installed last spring when this re-appeared. It snapped off the shaft. 10 years the stock one did just fine, 2 trips on this supposed billet upgrade, and it fails, go figure. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted September 26, 2008 Report Share Posted September 26, 2008 Props to Dave Noss for trying to help out as much as he has... Check the impeller seal, bearings, washers, etc to make sure you installed it right. Quote Link to comment Share on other sites More sharing options...
mailman Posted February 23, 2018 Report Share Posted February 23, 2018 Bump. I am having this same problem but my impeller is fine. Anyone else have this issue of the cooling system getting pressurized? Thanks. Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted February 23, 2018 Report Share Posted February 23, 2018 You may have to start a new thread and expound on your problem. Coolant gets hot, expands, the system gets pressurized, that's normal. Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted February 24, 2018 Report Share Posted February 24, 2018 (edited) I had that issue before. HOW pressurized is it getting? When I swapped domes last season I didn't seal my orings in good enough around the domes and It read 150 psi when I first tested. Took it to the dyno, started to spit coolant out (not projectile) but quite noticeably leak from the spit tube when it would run. I tested compression again and it was down 10-15 psi. I took the head off, resealed them with a little more Vaseline this time with new orings made sure they were pressed in real good and popped it back on. back to 150 psi on the dot with no coolant spitting. sorry for the story. Edited February 24, 2018 by Ayesully810 Quote Link to comment Share on other sites More sharing options...
mailman Posted February 24, 2018 Report Share Posted February 24, 2018 It is just pressurizing a little bit. I let the motor cool down completely then the radiator still is pressurized when I remove the radiator cap. There should be no pressure in the cooling system once a motor completely cools down so I know the orings are leaking a little. The motor never overheated. It seems like I am not getting a perfect seal with the domes on the cylinder. It is a cub cylinder and a Noss head. I guess I need to check the cylinder for flatness. Any chance the domes could be damaged in some way? I was thinking of sanding them down a little so they put more pressure on the orings. Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted February 25, 2018 Report Share Posted February 25, 2018 I wouldn't sand the fire rings but definitely check them. Occasionally I will see electrolysis Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted February 25, 2018 Report Share Posted February 25, 2018 O rings do break down over time. Fuels/temp/coolant used all plays into it Quote Link to comment Share on other sites More sharing options...
