how are the kick starter rebuild kits?
bigwake
  • 3 weeks later...
you can buy the spring, check ball, o ring and bolt from yamaha cheaper than you can get one of those kits for, as long as the kicker lever itself is not wore out inside they work great
How hard is it to do? Does the ball bearing have to be pressed in or anything? Ive never opened one up.
Thanks
  • 1 month later...
  • 2 weeks later...
  • 4 weeks later...
i did the cascade rebuild kit too. it helped a lot, but after a few rides it started rattling a bit again. i went to a machine shop and found a tapered spring and used about half an inch of it. just put it above the post in there so it keeps pressure on both peices. hope you can understand what im trying to say lol but there is no rattle whatsoever anymore.
