OK! Who has used it and what have your results been?? I just did my wife Discovery II and am about to do my Ranger.
Hers smoked so much when we drove down the road, people were honking cause the back looked like it was on fire from all the smoke!! Got a can in the tank to clean the injectors. I would highly recomend it!! Anyone else used it before?
  • Replies 34
  • Created
  • Last Reply
Top Posters In This Topic
It's really good stuff, I think it really works wonders on cleanin' out carbon. I've had really good luck with using it on both carb'd and fuel injected engines...
It does make them smoke alot, but I try not running them in any traffic when I do, just to keep myslf from looking like "Uncle Buck" out in public.... :geek:
I never heard about it before but I just put it into my truck about 2 minutes ago so we will see. I have 71000 on it. I am doing it in the dark cause I live in Santa Monica and them neighbors dont like my kind! lol I was going to use it in the oil but I think a engine flush is better. Or so I have heard..
Pretty good stuff but if you want the real deal, try BG 44K...it will actually clean the Cat as well as everything else........look it up at www.bgfindashop.com ...Jim
Edited by PassionRE
How close will adding this stuff be to actualy having the fuel injectors cleaned by a dealership? I'm at 42k on mine and have been putting in Lucas Oils injector cleaner / Fuel Addative after every oil change or 2.
[/quote
If you add the 44K before you starting gumming up the injectors badly it will clean them extremely well. It will also clean the valves,pistons, ring grooves, and cat in one tank of gas. The 44K is the only professional grade add to the tank additive to my knowledge...most of the off the shelf cleaners are all hype....Jim
Seafoam works great, in the 8 years I've sold auto parts, I bet I sold more of that then anything else. Garages that bought our parts used it with good results and also the chevron with techron was another one that worked. Jim is right, alot of the additives on the market don't work. It's always good to get feedback from garages, sure helps limit inventory.
  • 2 weeks later...
Do any of you have any knowledge with it in Diesels? I believe it says on the can it can be used in Diesels..but I'm a little iffy to try it. I run 2 stroke oil in my truck right now, so maybe I could run this stuff and see what it does.
Not sure if the Sea Foam can be used in diesels...but BG has killer diesel cleaners and additives..not trying to push BG, but no joke, BG is the real deal...Jim
bg's products work great the sea foam is ok to use in diesels when i change the ole fuel filters on fords i fill them up wth sea foam. then they start easier.. if the vehicle you ran the cleaner through ran good with it but then went right back to the prolems its got some major isues that "majic" ceaner wont fix. probably stuck injector or a fuel leak iternal to the intake also the good ole plugs, andfilters can cause these isus as well. there is NO "tune up" in a can ...
  • 1 month later...
  • 4 weeks later...
My friend used it on the " D " And it smokes like a beast. You have to suck it through a vacume line on the engine (usually off the brake booster) After the seafoam is put through the engine it is supposed to clean all the carbon and debris in the engine to make it run and idle smoother...
