XxGlamisDunerxX Posted October 16, 2007 Report Share Posted October 16, 2007 My banshee lost a rod bearing in the crank, so we decided to get a stroker crank. We've been wanting to do this for a while. I haven't had the time to ask my pops more info about it, so I was wondering how significant is the power gain from a 4mil stroker? We are currently bored .30 over with wisecos' pistons. Is there a formula to find out the displacement? Any other comments would be appreciated. Thanks Eric Quote Link to comment Share on other sites More sharing options...
WALLACE84 Posted October 16, 2007 Report Share Posted October 16, 2007 Running a 4 mill at .030 over would make it about 381cc or so. .020 over with a 4 mill make a 379 and a .040 over makes it a 385cc so it would be in between. As far as power gains go, I personally think it doesnt do awhole lot without porting. Or at least I couldnt really tell that big of a difference :shrug: Quote Link to comment Share on other sites More sharing options...
Hilarious Posted October 16, 2007 Report Share Posted October 16, 2007 My banshee lost a rod bearing in the crank, so we decided to get a stroker crank. We've been wanting to do this for a while. I haven't had the time to ask my pops more info about it, so I was wondering how significant is the power gain from a 4mil stroker? We are currently bored .30 over with wisecos' pistons. Is there a formula to find out the displacement? Any other comments would be appreciated. Thanks Eric I dont know if you would notice much of a gain with stock porting but, there is definately extra power to be had with porting and the extra 4mill of stroke. If you know you have problems with the crank, rods and bearings and have to open the engine you might as well throw the stroker in there. :beer: Quote Link to comment Share on other sites More sharing options...
SHEE157 Posted October 16, 2007 Report Share Posted October 16, 2007 What you doing over here Glamis Duner get back to the LTR site, haha. Quote Link to comment Share on other sites More sharing options...
XxGlamisDunerxX Posted October 16, 2007 Author Report Share Posted October 16, 2007 I dont know if you would notice much of a gain with stock porting but, there isdefinately extra power to be had with porting and the extra 4mill of stroke. If you know you have problems with the crank, rods and bearings and have to open the engine you might as well throw the stroker in there. :beer: We already have really good porting on the bike. We took the motor apart last night, the case is split and waiting for a new crank. Should be a fun project What you doing over here Glamis Duner get back to the LTR site, haha. Haha..I have the best of both worlds man, LT-R and Banshee. Quote Link to comment Share on other sites More sharing options...
WALLACE84 Posted October 16, 2007 Report Share Posted October 16, 2007 We already have really good porting on the bike. We took the motor apart last night, the case is split and waiting for a new crank. Should be a fun project You wont be able to run those cylinders. They have to be ported for a 4 mil Quote Link to comment Share on other sites More sharing options...
ZR2Freak Posted October 16, 2007 Report Share Posted October 16, 2007 Youll definitely have fun witha 4mil ... just make sure u listen to the guys on here what they tell you about what youll need to run ... Talking with Jim at Passionracing...said with what im going to have done... ill end up with almost an 80HP engine :biggrin: ... so its going to be interesting!...cause thats by far more than ill ever need...so yes.. The porting is what brings the 4mil's to life... a killer port job is key.. just depends on how deep ur wallet lets you go.. Quote Link to comment Share on other sites More sharing options...
SHEE157 Posted October 16, 2007 Report Share Posted October 16, 2007 That makes two of us with the best of two worlds, and loving it. Quote Link to comment Share on other sites More sharing options...
Animalman294 Posted October 16, 2007 Report Share Posted October 16, 2007 If its comin' apart now and you need a new crank, I would go with the stroker crank, because you can only go up from there............... Quote Link to comment Share on other sites More sharing options...
WALLACE84 Posted October 16, 2007 Report Share Posted October 16, 2007 If its comin' apart now and you need a new crank, I would go with the stroker crank, because you can only go up from there............... Exactually but hes going to need new cylinders Quote Link to comment Share on other sites More sharing options...
XxGlamisDunerxX Posted October 16, 2007 Author Report Share Posted October 16, 2007 (edited) Exactually but hes going to need new cylinders Why is this Is it because of the port timing? Edited October 16, 2007 by XxGlamisDunerxX Quote Link to comment Share on other sites More sharing options...
Hilarious Posted October 16, 2007 Report Share Posted October 16, 2007 Why is this Is it because of the port timing? Yes. There's a couple ways to run the stroker crank. The most popular is to have your cylinders ported and your head machined, or domes if you are running the cool head, for the additional 4 millimeters of additional stroke. Or, you use this spacer plate and I believe it goes between your cylinders and top case. The deal with that is you have to use (2) base gaskets which, in worst case scenario will give you an additional potential area for an air leak. To stroke or not to stroke. That is the question. Lol Quote Link to comment Share on other sites More sharing options...
XxGlamisDunerxX Posted October 16, 2007 Author Report Share Posted October 16, 2007 We were going to use spacers originally. We just bought these cylinders from a prior rebuild we did. Quote Link to comment Share on other sites More sharing options...
No Limit Powersports Posted October 17, 2007 Report Share Posted October 17, 2007 Spacers or cut domes either way will work depending on your prefrence but the port timings need to be addressed they will not be correct after stroking. Not saying it will not run it very well may but it may run worse than before cannot say cause i dont know how they are ported now. I would def get the cylinders to your favorite builder and tell him your going with a 4 mill so they can be corrected. Quote Link to comment Share on other sites More sharing options...
gumby6t9 Posted October 17, 2007 Report Share Posted October 17, 2007 Do you have to run a spacer plate if you run the wiseco pistons made for stroker motors? Quote Link to comment Share on other sites More sharing options...
