bigwake Posted October 16, 2007 Report Share Posted October 16, 2007 just put new/used carbs on my banshee..they run great..my problem is that when the gas is on, the right carb spits gas out like a fountain out of the yellow drain line near the swingarm (the lowest line on the carbs)..why is this? is it the floats? waht could it be? any ideas would help..thanx Quote Link to comment Share on other sites More sharing options...
2strokespirit Posted October 16, 2007 Report Share Posted October 16, 2007 just put new/used carbs on my banshee..they run great..my problem is that when the gas is on, the right carb spits gas out like a fountain out of the yellow drain line near the swingarm (the lowest line on the carbs)..why is this? is it the floats? waht could it be? any ideas would help..thanx Check your float level it should be 21mm without the gasket or your needle and seat has dirt in it, or the seat o ring needs to be replaced, or the hole needle and seat needs replacing. Quote Link to comment Share on other sites More sharing options...
bigwake Posted October 16, 2007 Author Report Share Posted October 16, 2007 Check your float level it should be 21mm without the gasket or your needle and seat has dirt in it, or the seat o ring needs to be replaced, or the hole needle and seat needs replacing. ok thanx..i took it apart and shot carb/choke cleaner everywhere..now im putting it bak on and cheking if it helped Quote Link to comment Share on other sites More sharing options...
bigwake Posted October 16, 2007 Author Report Share Posted October 16, 2007 ok thanx..i took it apart and shot carb/choke cleaner everywhere..now im putting it bak on and cheking if it helped fixed it Quote Link to comment Share on other sites More sharing options...
